How to tighten handle
This model comes with two types of doors. One with a single panel with integrated control on top or a two part door with control unit in front. The handle varies.
If you have a single door panel with handle bar across from right to left then you need to carefully unscrew the back panel screws and free up the front panel. the handle is screwed to the front panel from inside. Once you tighten carefully put the back door panel in and tighten. Take photos along the way to make sure you get back where you started. Also unplug dishwasher before working on it.
If you have a two part door with front control then handle and access to it is different. See diagram on this website for blow up of the panel and location of handle (part 713).
ESCUTCHEON DOOR ASSEMBLY Diagram Parts List for Model GLD5868V15SS GE...
You can magnify the image or take a full screen view for clarity.
SOURCE: My bosch dishwasher handle is loose
Hi rsouthwick,
I'm Harvey the Master Plumber.
You want to know how to tighten a bosh d/w handle?
Easy! open the door and look around the perimiter. You'll see screws on the right and left, they hold the front panel on. Simply remove them. The front panel is off and you can tighten away!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: GE Monogram ZBD0710 Dishwasher
THIS IS THE SOLUTION!
I was having the same problem with my Monogram dishwasher and oven.
Here's what to do.
You must fully remove the handle from the appliance.
Down the barrel of the standoff is a hex screw that, when tightened with an allen wrench, will draw the standoff tight to the handle again.
There is no need to remove the end caps.
SOURCE: Bosch Door Handle: Loose
I had the same problem with my Bosch dishwasher.I came to this web site to find out how to get the door off.I took the experts advice,placed 4 pillows on the floor in fromt,opened the door,took out the screws and the front panel dropped down.It was so easy,the plastic spacers stayed in place.I put a little J B weld on the handle screws and tighted the handle and put everything back together,12 minutes tops.Thanks for the help,thankful in Georgia
SOURCE: monogram dishwasher-loose handle
Here are some manuals, maybe they will help, I haven't personally down what you are asking about, but maybe one of the manuals has an exploded view.
Thanks.
ZBD6880 GE Monogram Dishwasher
ZBD6880 GE Monogram Dishwasher Owners Manual
ZBD6880N00SS GE Monogram Dishwasher Owners Manual
ZBD6880 GE Monogram Dishwasher Owner's Manual
ZBD6880K00SS GE Monogram Dishwasher Owner's Manual
ZBD6880K03SS GE Monogram Dishwasher Owner's Manual
ZBD6880K15SS GE Monogram Dishwasher Owner's Manual
ZBD6880N00SS GE Built-In Dishwasher Install Instructions
ZBD6880N20SS GE Built-In Dishwasher Install Instructions
ZBD6880 GE Monogram Dishwasher Manual
SOURCE: loose door handle on bosch integra ltd. dishwasher
you can loosen the inside of the door with a small torx screwdriver and lift it up far enough to get to the screw that holds the handle from the inside. I did this with mine about 1 year ago.
