Why does it stop moving ? what will cause the mower to slow down and then stop ? then after it cools down it will go again. what would cause that ?
If it is a hydrostatic transmission or automatic type transmission and it moves when cold yet bothers when warm or hot . I would almost bet your problem is within the transmission itself. If by chance it does have a fluid level cap or dipstick check to see if the fluid smells burnt or is discolored. Many of these transmission are a sealed unit not allowing the fluid to be checked. As suggested earlier make sure the transmission drive belt is in fact tight and not warn . A good test is once it begins to bother try to climb a small hill . If it slows down a lot chances are you are dealing with the transmission .Which can get quite pricey.
You have unseated valves the hotter it gets the less power you have until it stops to cool down need to take to shop and get vavle job about 100.00 dollars if you wait you will damage motor
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
SOURCE: mower stopped moving
If this is a manual transmission, check the drive belt from the engine back to the transmission. With the clutch pedal up (engaged) there should be no slack in the belt.
If it is a hydrostatic drive, check the drive belt and make sure it is tight. Check the transmission fluid level and make sure it is full. Refer to your owners manual as it will describe the fluid check proceedure.
Good luck, let me know.
Regards,
SOURCE: Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
SOURCE: Sears ZT 7000 mower, engine runs, mower will not move
Same problem. The drive belt pulley tensioner spring broke. Replaced and everything worked great.
