I recently upgraded to "GToogle Chrome" and the horror story began. I dumped Google Chrome and it was okay for 24-36 hours. Then every time I tried to go to gmail it would promptly load up the bar to about 99% leaving a thin white sliver at the end. I would leave it on for extended times but then after 4-6 minutes it would say it "has experienced a problem and needs to shut down." ::poof:: back to the screen - Only going to the older version works but now I can't find it.
I HONESTLY BELIEVE "GOOGLE CHROME" HAS A VIRUS.
gmail suddenly freezes. Everything else works except gmail. I was able to briefly reinstate by selecting "older version." But it quickly began freezing after processing only 3 emails. HELP!!!!!!!!!!
Maybe you did not download Chrome directly from Google?
Download the free version of Malwarebytes (Anti-Malware) from https://www.malwarebytes.com/ and install it; then run it (takes an hour or more) to see if it can locate and deal with any malware in your computer. Then uninstall Chrome, reboot. Finally go to https://www.google.com/chrome/ and download genuine Chrome again. Install it, run it. Le's hope it works this time!
SOURCE: Google Chrome hangs on startup
You have the latest version of Google Chrome - but it is still in BETA. I'm using the same version on Windows Vista Home Premium and I haven't seen the same problem. My advice would be to use a different browser such as Firefox, Safari or Internet Explorer until Google Chrome is past the BETA stage gate.
See http://www.mozilla.com/en-US/firefox/
You should also check that all your Windows updates are current.
SOURCE: Google Gmail new version old version switch
Hi if you are using Fire Fox 2.0 above or IE7 and English as a Language then Gmail New Version is default.
If this does not fix please tell me
SOURCE: I have connectivity problems with the latest
Drilled down through Google's Chrome Tools, cleared 4 weeks of browsing data (cache, cookies) at their suggestion. Fixed the prob!
SOURCE: Chrome Keeps redirecting my fmail
I managed to fix this problem by:
1. clear my browser history (cache)
2.
Go to google main page http://www.google.com and click the "sign out"
link at the upper right corner - just near your google id..
once signed out. try to login again. I am using firefox 3.5.6 by the way :)
SOURCE: Using gmail causes my internet to freeze
Try to optimize your browser like deleting your cookies, temp files and folders and history. You may also try to disable some startup items in the system configuration utility window or run sfc/scannow in dos
