Dyson DC44 Animal Cordless Vacuum Logo
A
Anonymous Posted on Aug 27, 2014
Why can't I make my dyson dc44 work
Will not work. Have cleaned filter,emptied waste. No lights on charger so assume fully charged . Has been intermittently cutting out since new.
  • Official Brand Answer 2,572 Answers
  • Posted on Sep 17, 2014
Fixya Pro
AskDyson
Level 0:
Answers
2572
Questions
0
Helped
1769323
Points
6009
Hi there, it's Jack at Dyson.
I'm sorry to hear about the difficulty you've experienced with your DC44 Animal. In order to diagnose the cause of the issue and determine the correct resolution, we'd need to take you through some quick troubleshooting checks when you have your machine to hand.
When you have a moment, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a replacement part is needed, we can also confirm if this is covered under our 2-year parts and labour guarantee.
3 Related Answers
rustysheriff
Tony Groves
  • 344 Answers
  • Posted on May 28, 2009
SOURCE: Dyson cleaner keeps cutting out, no blockage found, filter clean.
1. Check the on/off button these can also be troublesome and if you've stood on the cable once or twice you could have a break in the wire and it's shorting, check by turning on and wiggle cable around where it enters machine.
2. Faulty thermocouple, it is held in a white plastic housing screwed with one T15 torx screw to the motor housing. You could replace it but I just shorted mine with some wire and it hasn't failed since and more importantly not caught fire yet!
small6363
  • 18429 Answers
  • Posted on Apr 16, 2011
SOURCE: dyson dc 31 was working
check all conections are clean on the battery terminals,this link is for the manual,
http://media.dyson.com/downloads/UK/floorcare/Manuals/dc31_origin_manual_uk.pdf
askdyson
AskDyson
  • 2572 Answers
  • Posted on Aug 24, 2011
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: Vacuum does not charge. According to the Dyson
    Sorry to hear you're having difficulties with your DC16. It's probably best if you get in touch with us directly so one of our experts can identify the exact cause of the issue, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Online Customer Support
    1helpful
    Can I leave the battery charger plugged in to my Dyson DC44 animal after the battery is fully charged
    i take mine off the charger just for safety seasons dont like leaving things plugged in after its charged.
    1helpful
    My Dyson DC44 animal has the MAX light on all of the time but it appears empty....any ideas?
    ring dyson for support it could be the micro particle filter is blocked up and needs cleaning.
    Dyson have really good support
    http://www.dyson.com.au/support/dc44/dc44-animal-bu/maintaining-your-dyson-machine/wash-the-filters
    2helpful
    2answers
    Is charger not working?
    If you have a DC voltmeter and can see the contacts in the charger, you may be able to see it the charger has a output. But with the newer electronics for battery charging, the battery may need to be in the charger to get a reading. My guess is you do have a bad charger.
    5answers
    Dyson DC44 Animal Handheld Vacuum, keeps cutting out
    dyson-dc44-animal-handheld-vacuum-keeps-ehecv3x4uj13pgwprhzrjmma-4-1.jpgThe battery falls slightly loose, so you have to fasten it securely to the body of the vacuum. I learned this from another user here on Fixya. He uses electric tape. I used one of those rubber bracelets that kids wear. Worked perfectly!
    1helpful
    2answers
    Green light on DC44 but nothing is happening
    Hi Emma, it's Jack at Dyson.
    I'm sorry to hear your DC44 Animal doesn't seem to be working correctly. If the green LED indicator on the machine lights up, but the machine itself doesn't run, this suggests the battery is flat. It could mean that it's not recharging correctly when connected to the docking station.
    It would be worth temporarily disconnecting and removing the charger cord from the docking station and plugging it directly into the machine - the machine should recharge fully within 3.5 hours. If the machine then works as normal the charger cord may not have been corrected fitted to the docking station.
    If you'd like further advice from our experts after you've given this a try, please call the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
    Not starting at all
    The issues with your DC44 Animal sound unusual, and we'd like to take some further details. If a replacement part is needed, we can also confirm if your machine is within our 2-year warranty period.
    When your machine is fully charged and easily to hand, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Our experts will be happy to run you through some quick diagnostic checks to help determine the best course of action.
    DC 44 animal wont charge. Charge light comes on then off after about 30 seconds.
    Hi Darren, it's Jack at Dyson.
    I'm sorry to hear you're having difficulty recharging your DC44 Animal. It should charge from flat within 5.5 hours when connected to the charger assembly, or placed in the docking station, as shown in the video above.
    The charge light will turn off once the battery is fully charged. If it seems to be shutting off prematurely, we would need to take you through some quick diagnostic checks when you have the machine to hand. This will help us confirm what may be needed to resolve the issue.
    Please give the Dyson customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA), to speak directly with our team of experts.
    Best wishes,
    Jack
    www.dyson.com
    Loss of suction
    I'm sorry to hear you've had difficulty with your DC44 Animal. It's normal for air to blow out of the back of the machine - this is where the exhaust air is returned to the room after passing through the cyclone pack.
    However, if your machine doesn't seem to be picking up as well as usual and you've recently washed the filter, this may be due to a blockage. To check the motorised carbon fibre floor tool, wand and bin inlet for any obstructions, please follow the steps shown in our online Support guide:
    http://www.dyson.co.uk/support/dc44/dc44-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual-dc44/no-resolved-redirect-to-check-the-wand/check-wand
    The motorised carbon fibre floor tool is driven by it's own motor, rather than the machine's airflow. If it isn't rotating, the video attached should help you locate anything which could be jamming the brush bar. Make sure you remove any threads or hair from around the brush bar carefully using scissors, taking care to avoid causing any damage to the bristles.
    I'm confident this will resolve the issue, but if you would like some further help you can reach the Dyson customer Helpline directly by calling us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack - Dyson Online Customer Support
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Sean Wright
    Sean Wright
    xxxxxx xxx
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
