SOURCE: Not draining water and water does not shoot out of sprayer arm
try cleaning the drainat the sink alot of time gunk will build up in the connector to the sink very easy to look at as far as one4 sugg it sounds like the motor may be jammed or soething is in the pump you can get the special bit at lowes or your local hardware store i cant rember the size off hand i get them in alot of different sizes at a time so i have them on hand If any one knows the size please let them know thanks
bil
SOURCE: Maytag Model WU482 Dish washer completes cycle but
Check the hoses and air gap for clogging. Air gap is located under the sink between housing seawar line and dishwasher hose.
If no help check/replace drain valve
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=replace-drain-valve
if no help drain pump might be faulty.
Good Luck
