Huh? The USA does not have a single ZIP code. Every community has one or more ZIP codes, and they are further broken down with a 4-digit extension (optional) that gets the sorting down almost to the house number.
Likely, 3 days. In my experience mailing from a zip code that begins with the number "2" to a California zip code beginning with a "9"...it typically takes 4 days. Mailing from zipcode 2_ _ _ _ to any zipcode beginning with a 1, 2, 3, or 4 takes 1-3 days. (Zip code numbers increase as you move west across the USA, and I think the LONGEST a 1st class letter usually takes is 4 days.)
Please be informed, Fiji does not use Zip/Postal Codes because the
country is not very big. It only applies to a country which has
numerous states e.g. NZ, USA , UK etc. Fiji does not use zip
codes.Leave zip code box on address, blank or put in any 4 digit
number.It does not make a difference.Fiji Postal Service sends mail to
the Name and Physical address and does not take into account,the zip
code.
In the USA, the 'ZIP' code either is FIVE characters or NINE characters.
In Canada, the Postal Code is SIX characters, e.g., M5W 1E6 ("Make 5 Wieners, I'll Eat 6").
So, the web-site is narrowly-focused on ZIP codes in the USA, not in your country.
In order for you to get the zip code of United Kingdom, you have to verify first what is the city name because there are a lot of cities with different zip code in the UK. I have a link here where you just have to key in the City name and they will find the corret zip code in a certain place in UK.
The USA does not have a zip code. Each _City_ in the USA is assigned its' own individual zip code. IGo to this website: http://www.zip-area.com/ , select a State in the left column, then select a City. It will then give you the zip code for that City. The website also has a reverse lookup. All USA zip codes are 5 digits, so if you type in 33617 in the search box, it will tell you that is the zip code for Tampa, Florida. Large Cities have more than one zip code. For example, if you type 33615 in the search box it will also return Tampa, Florida. In fact if you type almost any thing starting with 336** it will return Tampa, Florida.
