Will not operate, red low ink light stays on
SOURCE: Epson STYLUS CX3900 Black colour not printing
Are you using gen. epson cart? If not then try that first.
Sounds like you have a block black print head there are many posts on that subject.
SOURCE: epson 2400 paper red light and ink red light
It sounds like your printer has reached what is often called the "service required" stage...
To solve this you need to handle two things.
1. Get the printer protection counter (or waste-ink as it's sometimes called) reset.
2. Replace the waste ink pads OR redirect your waste ink flow to an external tank
It's important to note that Epson will encourage you to do a waste pad replacement through one of their service centers, but if you're out of warranty this will cost a significant amount of money (approx: $100 - 200)
To solve these as a DIY you can do the following:
1. Resetting the counter...
Get a resetter, either the SSC utility (google: epson SSC utility) or the IPR utility that Epson have now made available via their website here
The latter is only available to North American printer owners so the SSC is a safer bet.
2. Redirecting waste ink to an external container.
This is something I'd heartily recommend instead of trying to change the waste pads yourself... It's simple enough to do and a little googling using keywords "Epson R2400 waste ink tank" should get you all the info you need.
There are simple kits available that offer everything you need or you can easily go for a DIY with bits you have to hand.
Hope that helps...
SOURCE: EPSON Stylus NX110 - 1st Ink Cartridge Replacement
you better have your printer check by a qualified printer tech thus avoiding any further damage to the printer the printer head is the most likely problem to
