HEWLETT-PACKARD HP ProBook 6550b Notebook Logo
A
Anonymous Posted on Aug 27, 2014
Blinking light on laptop?
Laptop booted up and I entered my password which was accepted but windows does not boot up and screen is dead but the start button light is blinking
1860ph
Level 1:
  • Contributor 30 Answers
  • Posted on Aug 28, 2014
1860ph
Contributor
Level 1:
Answers
30
Questions
0
Helped
5322
Points
54
From Hp the blinking light indicates sleeping mode. Suggest you push the power button for 20 to 30 seconds. The light should go out. Repower on the computer. If it goes back to blinking mode then there is a hardware issue.
3 Related Answers
GG TECHNOLOGIES
  • 201 Answers
  • Posted on May 15, 2011
SOURCE: Black screen, Blinking cursor for
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Sep 15, 2011
SOURCE: no boot blinking cursor will not boot
Hi buckyno2..
Try these solutions to your problem
Start your computer in the Safe Mode.
To start in Safe Mode.
Turn your computer on.
Keep tapping F1, F2 or F8 (depending on your computer) while the computer is starting up
When the computer starts select Safe Mode
1. Uninstall any softwear you may have put on the computer before the problem started.
2. Do a complete System Restore: Start>All Programs>Accessories>System Tools>System Restore.
This will bring your system back to a time before you installed the softwear or Microsoft installed drivers,etc.
Note: Just be sure to use a date in a darkened box, that is before your trouble start date.
When you have done the above, restart the computer and if your still having the problem, then the installed drivers,updates,softwear,etc might have
corrupted the Operating System.
If that happened then that means either repair or reinstall the operating system.
You will need to do the following:
1...Repairing the Operating System...
A...You will have to have the Operating Dics that came with the computer.If you did not make any or none has been made since you have had your computer, then you may be able to make the CD/DVD's for your computer.
Check in the Programs and see if there is a program that will allow you to make a back-up CD/DVD's for your system.
Note...If you do not have the disks that came with your computer or the ones you should have made when you first got your computer...then you will have to go to the manufacture's webpage and see if they have a recovery disk available for your computer, if they do not a recovery disks available then you can also try ebay to locate the recovery disks.
The original disks will have your product key number that came with the computer, you can also find it on the tower, or under the bottom of your laptop, or maybe the piece of paper that the CD orginally came in may have the number on it.
You can also download a small program and it will tell you your product key number.
Go to the following webpage to download your FREE key finder.
http://www.magicaljellybean.com/keyfinder/
B...You will now insert the disc into the CD/DVD player
C...Restart the computer
D...When the window opens that tells you to press "Any" key, you will press any key you want to press.
E...If you do not receive a message that says "press any key to boot from CD", then then the computer is not ready to boot from a cd.
To correct this problem you will have to go into your computer's Bios and change the computer to boot from a CD.
To get into the Bios, shut the computer off,restart, while the computer is starting up keep tapping F1 as the computer is starting up.
When you are in the Bios, select to boot by CD by moving the cursor with the direction arrows on the keyboard.
Once you have selected to boot by cd the exit and restart the computer...the disc is already in the cd/dvd player.
Your system will then boot from the cd.
F...After a minute or less it should ask you if you want to Quit Repair, or Continue.
You will select Repair this time, but you may have to come back here and select Install if the repair does not work.
It will ok the agreement document if it asks you too.
Tap F8 on your keyboard to pass it when ready.
It will ask you if you want to Install, Repair, Delete Partition, or Quit.
Select Repair
Inside the box there will be one or two partitions.
Choose the largest partition.
After you have chosen the largest partition, you will then press the "r" key to start the repair
After the repair is complete, then you will need to restart your computer.
G...Computer Restart
After the repair is complete, shut the computer down (the computer will shut down a few times during the installation of the operating system
that is normal).
Then restart your computer, when the computer restarts it will have a box to put your product key...put the product key in the box and click.
The computer should start up and run as if it was a new computer.
You do not need to re-register
You can now remove the disc.
If this fails to clear your problem then you may have a hardware problem.
It could be faulty ram
If you still have the same problem, then you have two choices.
1.Reinstall the entire Operating System and you may have to update some drivers.
This will require you to go back to the start of the repair info and select Install instead of Repair.
2..Take your machine in to have the hardware tested.
Keep in mind that if you do a complete reinstall of the Operating System you will lose all the information on the computer,such as pictures, programs, videos, everything you installed will be gone.
Please take time to rate me four thumbs up
bendarden
Ben Darden
  • 984 Answers
  • Posted on Sep 16, 2011
SOURCE: G42-415DX laptop - will not
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave', for today.
I suggest that you click on the following link to retrieve the HP G42-415DX maintenance and technical manual: Free Maintenance Download
All the best
Ben
1helpful
I forgot my laptop password
You can try the following:
If your S.O. is Windows you can try any Windows Password Recovery Tool
Alternatively you can ty( if Windows):
Step 1: Boot or Reboot your Windows laptop (it is a Windows 7 example ).
Step 2: Hold on F8 to enter Advanced Boot Options before the Windows 7 loading screen appears.
Or Press CTRL to enter Advanced Boot Options when computer power on.
Step 3: Choose Safe Mode with Command Prompt in the coming screen, and press Enter.
There are three options for choice, Safe Mode, Safe Mode with Networking and Safe Mode with Command Prompt. In order to reset Windows user password with command prompt, select Safe Mode with Command Prompt.
Step 4: Wait for Windows 7 to load files until Windows login screen comes out.
Step 5: Log in with an administrator account or built-in administrator when you see login screen.
Step 6: Command Prompt runs automatically. Type net user in the Command Prompt and press Enter to see how many user accounts in locked laptop. Then all of laptop users will be listed in the Command Prompt.
Step 7: Choose one administrator to reset forgotten password for laptop.
Type net user fuzi 123 and hit Enter. Suppose 'fuzi' is your locked Windows user name. Then '123' would be new password you reset for it.
Step 8: Login your laptop with the new password after successfully laptop password reset.
3answers
I forgot my password
You will need to reinstall windows
I FORGET MY IBM THINKPAD LENOVO T60 BIOS PASSWORD, NOW HOW I ENTER IN BIOS. PLZ GUIDE ME. S.VIRANI
Hi
Remove to your BIOS password download the CmosPwd, and follow the mention below instruction.
Typical Usage for DOS and all Windows users:
1) Identify your BIOS manufacturer (usually displayed at boot-up)
2) Start in DOS, or start a DOS session in Windows 95/98/ME. For Windows NT or Windows 2000 boot from a DOS or Windows 95/98 boot disk (you can find boot disks at www.AnswersThatWork.com), and run CMOSPWD from your boot floppy (or another floppy).
3) C: [Enter] cd CMOSPWD [Enter]
4) Type CMOSPWD at the DOS prompt and press Enter.
5) CMOSPWD will display a list of possibilities. Use the possibilities itemised against your BIOS manufacturer. Remember :
a) For AWARD BIOSes, use the Numeric Keypad (with NumLock ON).
b) AWARD 4.50PG BIOS always accepts "AWARD_SW", or "d8on", or "589589".
c) Old Phoenix BIOSes will accept "phoenix".
6) If the standard method does not work, then try to kill the CMOS password with CMOSPWD /K (and press Enter), and then see if you can get into the CMOS without a password. If you can, you successfully "killed" the old CMOS password. DO NOT KILL THE CMOS ON LAPTOPS!
19helpful
4answers
Forgot Windows xp password
Don't worry - if you forgot Windows XP password, this article will show you several methods you can used to find a Windows XP password.
How can i reformat dell inspiron 1501? my laptop have a security by its administrator how can i remove it?
it was easy to me if you mention which types of operating system you are using i will tell you 5 steps in xp...
How to Remove an Administrator Password in Windows XP
1 Insert your Windows XP CD into your CD drive and boot your computer. If you receive the message "press any key to boot from CD," press any key.
2 Press "Enter" to set up Windows. After you accept the license agreement, you will be asked if you want start a repair process.
3 Press "R" to begin the repair process. Setup will now check your disks and start copying files, which can take several minutes. After this, reboot. Let the computer boot normally (do not press a key to boot from CD).
4 Keep your eye on the lower left portion of the screen. When you see the Installing Devices progress bar, press "Shift" and "F10" at the same time. This will open a command line console.
5 Type "NUSRMGR.CPL" (without quotes) at the prompt, then press "Enter." This will give you access to User Accounts. Remove or change your password. Write it down. After the repair is finished, you will be able to log on with your new password.
I'd like to remove or replace the password so I can use it for internet.
to remove the password take the following steps
  • Step 2 Press Enter to setup Windows. After accepting the license agreement, you wil be asked if you want start a Repair process.
  • Step 3 Press R to begin the Repair process. Setup will now check your disks and then start copying files, which can take several minutes. After this, reboot. Let the computer boot normally (do not press a key to boot from CD).
  • Step 4 Keep your eye on the lower left hand side of the screen. When you see the Installing Devices progress bar, press SHIFT + F10. This will open a command line console.
  • Step 5 Type NUSRMGR.CPL at the prompt and press Enter. This will give you access to User Accounts. Remove or change your password. Write it down! After the repair is finished, you will be able to log on with your new password.
  • Read more: How to Remove an Administrator Password in Windows XP | eHow.com http://www.ehow.com/how_4464321_remove-administrator-password-windows-xp.html#ixzz0sPSURE3v
    Press Enter to setup Windows. After accepting the license agreement, you wil be asked if you want start a Repair process. Press R to begin the Repair process. Setup will now check your disks and then start copying files, which can take several minutes. After this, reboot. Let the computer boot normally (do not press a key to boot from CD). Keep your eye on the lower left hand side of the screen. When you see the Installing Devices progress bar, press SHIFT + F10. This will open a command line console.
    2helpful
    3answers
    Password on both bios and HD ,no one knows where the passwords originated from,Acer Aspire 1353xc. How can I get past them?
    when you enter the password three times it will say it is wrong and you will have a error code. give me the error code and i will give you to default password.
    DVD drive keeps on opening when starting
    If the boot priority in the BIOS setup screen is set to thr CD it  will open the cd door every time you boot looking for the BOOT cd.    It will not accept anything else, at that point except a boot cd since it hasn't found the operating system (windows) yet.    By "blue laptop" you mean "blue screen" DO a "Windows restore" or reinstall windows from the reinstall cd or Harddrive partision containing the restore files.
    2answers
    Password unknown and no disk to restore
    The problem-- wait. Can you boot into Windows or whatever operating system you have? If you can't, that's a serious problem. Because if you forgot your BIOS password...you're screwed.
    2helpful
    2answers
    Remove bios pass word
    you can remove the bios password by removing the battery wait for 10 to 15 seconds then return power on. you can also reset this by transferring the cmos clear pins from pin1-2 to pin3-4 wait for 10 seconds then return to pin1-2 then power on.
    Top HEWLETT-PACKARD Computers & Internet Experts
    Paul Bade
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
