Ricoh SP C261SFNw printer
error SC 542
5. Execute "Reset Fuser Unit" with the "Engine Maintenance" menu if the fusing unit is replaced. "Menu Mode" can be executed by depressing the following key sequence while in ready condition: Clear/Stop, 1, 0, 7 and Color Start. (Press and hold each key till a beep is heard.)
6. Scroll to Engine Maintenance - Enter
7. Scroll to Reset Fuser Unit - Enter
You need to switch the power switch off.
Hold down either the online & escape or stop/start & escape while switching the machine on.
The machine should start up in service mode.
Select 1 for service mode
Select 5 for mode
Scroll to 810 SC reset and select enter
Select execute.
Switch machine off and on again.
1. Switch machine off.
2. Hold up and down arrows in while switching the machine on.
3. Select Service menu and OK.
4. Scroll to 5.Mode and OK.
5. Scroll to 810 SC/Jam reset and press OK.
6. Execute
7. Switch machine off and on again.
If code does not reset you would need to replace the Fusing Unit and follow the above steps again.
press the helpful button
found this on fixya by J Mcallister
Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
Yes your MFP has had a fuser reload error. It's not permanent though. Sometimes the thermistors don't read the right temperature due to the thermistor getting excess toner built up on it or it gets moved away from the hot roller. This SC error usually can be reset by powering down the printer. It must be powered down correctly or you can corrupt the hard drive. Hold the power button down on the operation panel until the screen goes dark. Then, physically turn the power switch off on the side of the unit. Once the unit has completely powered down and all lights are off, toggle the power switch back on. The unit should power back up normally. If the SC 542 returns, you'll have to have a technician check the fuser out.
hi there, try to do the following: - make a program mode (SP 107)
if you dont know SP mode, press clear/resume button then 1, 0, 7 then clear/stop button for atleast 5seconds. *the monitor should appear 1.system 2.copy3. then press 1, then press 7,8,0,7 then # *the monitor should appear COUNTER RESET then press 1 to start, let it finished then turn off and on your machine., *the SC-542 should disappear
note: if this will not fixed the problem, there maybe a problem with your FUSING UNIT, check it!
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
