Beko DRVS73W Vented Tumble Dryer - White Logo
A
Anonymous Posted on Aug 27, 2014
New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
New Beko DRVS73W tumble dryer installed by my builder recently. When switched on for the first time and set to dry it started but made a terrible noise. Got scared and switched it off. Tried to push the drum round by hand to see if it was ok but it only moves in an anti clockwise direction (cannot turn the drum in a clockwise direction). I asked the builder if the drum retaining bolts had been removed but he said they do not have any (unlike washing machines). Any idea what is wrong? Thanks.
colin_davie
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 08, 2015
colin_davie
Contributor
Level 1:
Answers
Questions
Helped
1065
Points
That model only goes in one direction.
Francisco Burgos
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Aug 28, 2014
Francisco Burgos
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
3433
Points
10
Check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
Beko DRVS6W tumble dryer squeaks when the drum comes to a halt
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Tumble dryer drum making a noise spinning
hi take top off hold back of drum see if u can pull it up if you can feel play its more than liklely the bearing wot dryer is it
Feb 13, 2014 • Beko Dryers
1helpful
Beko DRVS 62 W Tumble Dryer Squeakig
I had a problem similar to this on my Frigidaire dryer. I found that there is a felt ring that goes around the drum inside. This acts like a washer to prevent the drum from rubbing on the housing. On mine, the felt somehow got pushed in some and the drum was squeeking as it rotated. I had to order a whole new drum and replace it since on my model it was part of the drum.
Feb 11, 2014 • Dryers
Beko drvs73w dryer keeps breaking belts. Drum seems to jam at door end and motor contines to melt the belt.The bearings are good . The dryer is only 18 months old. Every time belt breaks when I investigate...
check your drum rollers/glides and your idler arm(it is suggested to change this with the belt), here is a website hope it helps,Tim:
http://www.partselect.com/dryer+inspect-pulley+repair.htm
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Mar 27, 2011 • Dryers
1helpful
2answers
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 • Dryers
1helpful
Noisy dryer
hi there,
the rattling and squeeling noise usually comes from the drum shocks. they do wear out due to use. i would recomend replacing them.
155helpful
10answers
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Top Beko Dryers Experts
ADMIN Andrew
ADMIN Andrew
How-2-Repair.com
How-2-Repair.com
Jorgie  the...
Jorgie the...
Are you a Beko Dryer Expert? Answer questions, earn points and help others
