Question about Frigidaire FFCE2238LW Microwave Ovens
<!-- from fixya rte -->How do i disable the beeper - Frigidaire FFCE2238LW Microwave Ovens
  • Official Brand Answer
  • 2,267 Answers
Hello Friend, thank you for allowing me to assist you!
I see that your question is listed under Frigidaire microwave FFCE2238LW. Typically you will hear a series of beep once your food is done heating or defrosting has finished. For this purpose, the beeping signal cannot be deactivated and I show that the volume is not adjustable for your model. Most microwaves are preset to do this. Best regards! - Z
Posted on Aug 28, 2014
6ya staff
SOURCE:
How do I disable the beeper on my Kenmore Microwave - 3310
normally there is no way on MOSt . we live with it
Dec 30, 2015 | Kenmore Microwave Ovens
My TMV151FB beeper stopped working. Is it worthwhile fixing it?
if ever thing else works but the beeper I would not worry about that
May 24, 2015 | Tappan Microwave Ovens
Beeper problem
wither it fell out of place or needs replacement
Apr 17, 2014 | Amana MVH230 Microwave Oven
Turn off beeping sound on touchpad oster countertop
If the owner's manual does not mention this as an option, the only other option would be to disable the piezo beeper.
Here's a video showing you one way:
Dec 02, 2013 | Westinghouse WST3501 Microwave Oven
Beeper wont shut off
Remove the power plug and Allow the voltage present on the board to drain OFF. After an hour please recheck and if the beep still stays there is fault in the motherboard. Possible that the beeper driver is short and is continuous. If all the other functions are working without any issues, all you can do is to cut off the beeper connection if you are able to remove the board and snip off . Attempt with power plug removed .
Nov 06, 2011 | GE JVM1850 1000 Watts Microwave Oven
Spacemaker xl (1999)low volume beep
According to the owner's manual (available here), there is a beeper volume on some models in this series. If yours has one, press it and then press 0 to 3 to control the volume (0 mutes the beeper and 3 is loudest).
If your model doesn't have the beeper volume control it's just that the beeper is going bad. They sometimes do that, getting faint or quitting entirely. You can't get a replacement beeper from GE, only the entire control circuit board.
The beeper is a piezoelectric type. Radio Shack sells a variety of beepers. If you know someone who can replace electronic components, they may have one that could be used on the board. Changing the beeper for one not the same as the original would not affect the oven's operation or safety, so that's an option. I'd do that myself if I were repairing this for a friend. But you might not be able to get a professional service shop to do this because of liability concerns. They would most likely replace the entire board.
With luck, your oven just has the volume down. Hope this has helped, and thanks for using Fixya!
Feb 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Loud horrible beeper
It's a safety device, mounted inside.
Feb 12, 2009 | Emerson Black Microwave Oven
Clock timer volume too low
The beeper sound level can be adjusted.
Press the "BEEPER VOLUME" pad on the keypad, then select 0–3 for mute to loud.
Your owner's manual is here.
Jan 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Disabling the beep on a Kenmore microwave
I have Kenmore microwave model 721.61820100.
It has an "Option" button. Press it. The display say "NUMBER"
Then press "1". The display should say "SOUND" and then "OFF".
Press "Start" and that beast turns silent, well not really, but the beeps are goooone.
If for some reason you don't like it this way repeat the sequence and the sound this time will turn "ON".
Jun 05, 2008 | Kenmore 80809 Microwave Oven
Frigidaire FFCE2238LW Microwave Ovens Logo
968 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
