White smoke would indicate a fuel problem. The engine is flooding.
There are a lot of possibilities but the first area I would check is the carburetor float level and inlet needle.
Did you notice this after the engine oil was changed. If you overfill oil it will smoke. Check oil level. Let me know if this helped. I have other ideas, but this is the most common problem with smoking.
Hik marie carten...
Normally white smoke coming out of the exaust will me one of two things.
You have overfilled the crankcase with too much oil and it is making the smoke, in which case you can drain the excess oil out and that should elimanate the white smoke.
Or, you have a worn out engine and oil is getting by the rings of the piston and being burnt in the combustion chamber of the engine.Which means engine overhaul, or buy a new mower.
Free answer...Please take time to rate me.
Pull air filter see if theres any oil in it,make sure the oil isnt overfilled. Push mowers usually smoke like that if theyre overfilled,or tipped on thier side,if there is oil in filter simply take filter off,drain oil to correct level,and run it till smoke goes away. If none of this is the problem rings are probably shot. Weedeater is a cheap brand and theyre made cheap too,not made to last.
Obviously it has had oil or similar inside it at one time or another. Have you given it enough running time to burn all that out? How old is lawnmower & was any work done recently to it?
You overfilled the oil. If the mower runs, just go ahead and mow grass until it runs the oil out of the gas tank. Or you can empty the gas tank and fill with new gas. White smoke is not a serious problem. Only a hassle.
