3-2 beep code
SOURCE: pride mobility scooter. turn key on it keeps
Are you sure that it not in FREEWHELL mode, lever at the back, Regards
SOURCE: Problems with Pride Celebrity X 4-Wheel Electric
It is often a damaged accelerator (Potentiometer). Sometimes the shaft on the wigwag breaks the contacts in the accelerator from being moved too vigorously when going over a bump too fast. A technician would need to repair this for you. Happy scooting. Regards Chris… [email protected]
SOURCE: brake not holding on incline
remove wheel then using screw driver
remove brake then replace and re screw
replace wheel
ted mobility centre penge 0208 676 0944
SOURCE: Pride celebrity x 3-Wheel scooter My scooter is
Hi
Trade it in for an 8kph Speed, as i am assuming that yours is only a 4 kph Speed,
Gerry.
SOURCE: PRIDE CELEBRITY DX RUNNING SLOW
Hi
Please Check your Potientiometer also known as a Pot, This is your Speed Control and it may be on the way out after 4 Years ,
My Own Pot Packed up after 11 Months, Try to get a Second hand one as they are Expensive to buy,
Good Luck, Gerry.
