E drive burns 99% then message box says an error was encountered -cannot finish disc
SOURCE: Help with burning off my home made dvd on my laptop Acer Aspire 5610z
TRY CLEANING WITH LENS CLEANER ELSE THE PROBLEM MAY BE ALIGNMENT NEEDS TO BE DONE AT SERVICE CENTER (RECOMMENDED /OPINION) ELSE CHANGE DVD ROM
SOURCE: the disc drive wont burn a dvd or even play cd or
was it preinstalled or you installed it yourself ? either way sorry to tell you but drives do give out, and some times the cd-rom and dvd - rom drives the hardest to fix, but you can research http://www.geeks.com/ and find yourself a new one for around 40-50 dollars...
another thing, if you installed this drive yourself, you can pull it out and check the jumper and make sure its either cable select or slave or master, which ever you want to set it up as....
i usally put all my drives in cable select so the computer will select which drives goes first and things are juts alot easier that way....
SOURCE: Won't burn DVD data discs, error code 0x207
Have you looked at this from ACER: http://acer--uk.custhelp.com/app/answers/detail/a_id/3410/~/error-code-0x207-shows-during-recovery-dvd-creation I'm sure you already know it seems to be a common problem. Every post seems to point to Media type , can't use RW disk, +or-, seems kink of finicky which seems odd. Only use DVD+R or DVD-R.
What you can do is attempt to repair the system using System Restore or startup repair. I would suggest trying startup repair first.
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista or Windows 7 installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Hope this helps
Ray
First please refer to the following thread to see whether it helps.
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=796452&SiteID=17
I know that you are unable to start the current vista operation system and getting the error 0xc00000e9; the issue can be caused by the damaged system files or hardware device. You might first follow the steps below to exclude the possibility of system corruption.
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
