1985 Mazda RX-7 Logo
Posted on Jul 01, 2009
Have a 1985 mazda rx7 will not idle .. cold start ok when choke is on once warm stalls and will not idle
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jul 30, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1945
Points
8
There is a throtle adjuster right behind the carb. You can adjust it with a screw driver. If you are not sure where it is, just have someone press to gas pedal and you will see it move. RPM's at idle should be around 1,000 when it is idle once it has warmed up. Once that car warms up the choke moves back in and the car is probably stalling because it is not running enough RPM's.
1985 Ford Ranger 2.3 starts and idles good. But when put in gear dies until it reaches full temp.
Hmm...........
1985..........
Probably carb? Automatic choke not working? Remove air filter and spray carb with cleaner, Make sure all parts move freely. With engine cold, check automatic choke position. Start and check function as it warms up.
1helpful
2answers
In cold weather, my car is slow to start and has stalled a few times. What should I check?
You don't say what make of car but it's about the same for all. Your problem is the choke adjustment. The choke raises the idle when the car is cold and after warm up drops to normal. You are doing the chokes job when you hold the pedal down, once its warmed up the choke no longer functions till cold again. So check the choke and the high idle speed adjustment. Simple fix. Hope this helps mike
Mazda rx7 idle
try running the fault codes to check which sensor has been affected by the over heat .
F150 stalls
I'm assuming the truck runs ok once it is warmed up. Sounds like you need to make some adjustments. The cold idle speed is set too high, and the choke is opening too fast. The cold idle should be around 1500 rpm and the choke should take at least 90 seconds to open depending on air temp.
1985 Nissan 720 ext. cab pickup problem
You need to adjust the automatic choke. Your choke may not be opening fully. There is a fast idle cam linked to the choke to keep the throttle open more until the engine is warm. The idle mixture screw is part 37 in the picture, but get the choke adjusted right first, and you may not have to adjust the mixture screw. See adjustment procedures at link beloe.
Repair Guides Carbureted Fuel System Carburetor AutoZone com
My 1984 rx7 starts when choke is pulled out. WHen engine warms and choke pulls in it stalls out. when trying to start it back up the engine sounds like it's trying to start, and it does when I pull the...
try removing air filter and spaying CARB CLEANER in carb while holding open intake rub thouroughly with hand in side carb, start vehicle and run... spray more cleane and by hand throttle open and spray reinstall filte and runner good on open stretch of highway.
see how that works
Your carberater is having problems getting the correct amount of fuel.Either a line or fuel filter is clogged or you need to have your carb. rebuilt.
83 Rx7 stalls when cold unless I keep applying pedal pressure
these cars are carburated motors and need around 10 minutes to warm up because they operate at higher temperatures.
Cold starts 1985 plymouth colt 4Dr dl sedan 1.5 L
If yours is a Mikuni carb, here's what I did to make my choke work manually on a 1986 Plymouth Voyager:
http://imhdd.ms11.net/CHOKE/choke.html
1helpful
1985 rx7 13b will not hold idle
A large rubber hose feeds air to the large block with "RE-EGI" cast into it. Between that intake hose and the RE-EGI block, called the dynamic chamber, is the throttle valve. You can adjust the idle speed by adjusting a screw in the top of the throttle valve to 800 rpm.
Top Mazda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mazda Expert? Answer questions, earn points and help others
