Turn camera off, remove battery's and sd card. With everything out turn it to the on position for about 2-3. After 2-3 minutes put batterys back in while on the on position. Once he says no card or no memory turn the camera off put sd card back in and test the camera.
Has this to do with difference in europeen and american time and date? Like europ: DD/MM/YY american: MM/DD/YY europ has 24 hours clock america 12 hours with AM and PM.
Go to your menu button go to camera setup then general hit the right arrow key where says erase images hit ok say yes this should fix your issue. Make sure you don't have pic you want to loose.
The red light is the infrared, this is not a white flash camera you can view pic on that camera by going to playback. How to get there hit your menu button go to camera setup and then go to playback and hit enter you should see them then. If still not working call Moultrie 8006533334 option 1 and 1 for a live person will need equipment to troubleshoot the issue.
