Dc, I know very little about axs4g so I did a google search and It looks like you should delete the app watchdog. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Take trio AXS 4G OUT od demo mode My trio AXS 4G somehow is in demo mode... Trio Tablet Support
Your tablet is stuck in demo mode, to reset the demo mode shut off the tablet, keep pressed at the same time power+volume up buttons, the tablet will boot in recovery move, the last selection of the menu is the demo mode feature 0n/off
Take it back in to where you bought it. They set it up in demo mode so they should be able to tell you how to turn it off. You can also go to the manufactuer's website and get the number for tech support and they will help you. They want a satisfied customer. Also if the tablet has phone capability like ATT or Verizon they can help get it out of demo mode.
Please follow the below mentioned procedure to disable Demo Mode in Acer Iconia Tablets.
Tap on Apps in home screen - Settings - Storage - Internal Storage - Apps - Scroll down and Identify "Demo Video Application" under the apps list .
Tap on Clear Cache and tab on "Disable", Ignore the warning message. Note: Cust may see the "Demo mode" icon in the homescreen, however it wont bringup Demo Video
Regards
Go to SETTINGS; Go to DEVICE; Select APPS; Side scroll to right until you find DEMO VIDEO at the bottom of the page; Select it and follow the indicators to DISABLE the VIDEO MODE. Restart the tablet. The 'demo mode' will still appear in on the lower left of the display but the mode is DISABLED.
Where did you get the tablet? I believe you purchased a store demo tablet. If you you browse zeepad's website you can probably restore the firmware and get rid of store demo mode.
Disabling store demo mode
If you consider installing the configuration file included below make sure you understand how to disable this mode first.
Mobile configuration files are used to configure phones in enterprises. Apple provides an app called the iPhone Configuration Utility (IPCU) to install and remove configurations. To disable store demo mode:
Use IPCU to remove the configuration from the phone
