The error code 726.6 on the Duravit Sensowash Stark f plus indicates a water supply error. This could be caused by a few different things, such as a clogged water filter or a problem with the water pressure. Here are some troubleshooting steps you can try:
- Check the water supply: Make sure that the water supply valve is turned on and that there is adequate water pressure. You can also check the water filter to see if it is clogged.
- Check the wand: If the wand is not functioning properly, it may be clogged with debris or lime scale. You can remove the wand and clean it with warm water and a mild soap.
- Reset the unit: Try resetting the unit by unplugging it from the power source for a few minutes, then plugging it back in.
- Check the wiring: Make sure that all of the wiring connections are secure and that there are no loose wires.
If these steps do not resolve the issue, it may be a problem with the motherboard or another internal component. In that case, you may need to contact a professional for further assistance.
