Channel picker? I assume that is a channel changer right? Heh. Well, there are many, many, universal remotes. If you go to your local electronic store you can find some to suite your needs. Programming it is another story, but they call come with instructions.
Channel changer from the remote? or from the TV? if it is from the remote, that's an easy fix, take off the batteries open the back of the remote, clean the circute board the one that is painted green, clean the remote contact pads as well the one that has a black dot like thingy with cotton balls slightly damp in rubbing alcohol, let it dry put it back together and replace with a new battery.
have you tried to make any channel higher than 13 a favorite ch (program channels that you enjoy and save it) this can also be done on a cable converter box. and any time you want you can go through the loop of channel that you just saved . look at the booklet that came with remote
These are generic code search instructions for Phillips/Magnavox Programing with Code Search
1. Manually turn on (TV,VCR,etc.) to be controlled. 2. Press and hold Code Search button until red indicator stays on. Release the Code Search button. 3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blinks, then stays lit. 4. Press the Channel Up button repeatedly ( up to 300 times ) until the device to be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code. If the device you are installing does not have a Channel Up button use Play(VCR only) or Power, on all other devices.
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
Double check ALL your ant wire connections. Then reprogram the converter to check for stations again. If that doesn't work then reposition your antenna and reprogram again.
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
