Televison & Video Logo
A
Anonymous Posted on Aug 24, 2014
Is there a power fuse in a element flat panel tv
Karl Whisenand
Level 3:
Genius:
  • Master 1,554 Answers
  • Posted on May 11, 2015
Karl Whisenand
Master
Level 3:
Genius:
Answers
1554
Questions
Helped
753116
Points
4266
There is always a fuse in all tv's
if the fuse blew then you will most always find some other fried component.
3 Related Answers
Anonymous
  • 5 Answers
  • Posted on Mar 03, 2008
SOURCE: Polaroid LCD Flat Panel TV
There's a Standby/On switch which is the one that the remote triggers.(There's a tact button on the set, too). BUT there's a master 'rocker type' switch that cuts mains power to the set. Make sure that this master switch is on before you use the remote's on/off switch. It's usually hidden behind the set at the bottom, out of obvious sight.
Robert Billyard
  • 277 Answers
  • Posted on Jul 21, 2010
SOURCE: rca l32wd22 flat panel tv no power where is the
christy hope,
There is some good news
Take your tv to a TV service Centre and ask them to fix. If they cant fix it, take the work order from your service guys and call 1-877-297-8391 and get your tv
gopakumarg43
  • 76851 Answers
  • Posted on Aug 17, 2012
SOURCE: need a replacment lcd flat panel foe a Element tv
Check the number of the LCD panel and search for it on internet. There is model number to every LCD panal, can be noted on the panel itself; on a sticker. You have to open the TV to get detail about this.
Were is the power supply fuse on a 2014 65 inch element tv. Tv is not turning on
SI UN TV DE ESA MAGNITUD VOL? SU FUSIBLE NO LO REEMPLACES CAUSARAS MAS DA?O REVISA PRIMERO LA FUENTE Y ASEGURATE DE Q NO HAYA NADA EN CORTO ANTES DE REEMPLAZAR EL FUSIBLE..
I think my 55 in element tv had a power surge tv went to static then shut off when i was watching a movie on my dvd now no power the led light does not come on at all i open the back and i did not see any...
Are you competent in using a test meter? There is a high risk of electrocution if you are not! If you don't know what you're doing disconnect the mains and use resistance checks only.
Is there a fuse in the plug? If so check it for continuity
If not there will be a fuse on the power supply board which may be blown. This only applies if it is completely dead. You can check this by measuring the voltage at either end of the fuse.
You may need a new power supply.
My tv is not getting any power no lights turn on
try your tv in another part of the house and if it dos not work then the internal fuse may be gone
Tv model ELCHS261 WONT TURN ON?
There's a signal lights or power lights.?Plss check the fuse at the power supply, replace if busted.Thanks!!!
We have an Element TV FLX2611B. We have owned it three years. The TV is not getting any power. It is as if it is unplugged. I have check the fuse. Any suggestions.
The same thing happened to me when we mounted ours to the wall. I took the fuse out of it's holder and just put it in without the holder and it worked fine until today when we took down the TV to install a shelf above it. Now I can't get it to work.
2answers
Element FLX-2611B won't turn on. The red light is not lit
Just because fuses are intact does not mean it is not damaged. Sometimes a small spike of power does not blow a fuse but damages Transformer windings Before the fuse! If there are no lights picture or sound think powersupply transformer primary.
Element LCD tv with no power. I replaced fuse,
You probably need a new power source. Take it to you repair shop. That's what I had to do and it was relatively inexpensive.
1helpful
Element FLX 3211B has no power after 14 months of use. TV will not power on. Checked th fuse near the power cord and the fuse is good. There is no power going to the TV. Tested the power cord and it is...
Took it to a TV repair shop and they did the following:
1. Rebuilt Power Supply
2. Replaced Diode
3. Replacd Transitor
Total cost was ~$100. Tv works fine now.
No Audio no video on an Element FLX3710
Bad control board. ~$300. Take TV back to wherever you bought it if still under warranty or Purchase new TV.
Top Element Electronics Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
