Will not eject disc can't find any setting that to change that help.
SOURCE: EJECTING ERROR/LOADING ERROR
yes, i send it in to alpine and they adjust it for like $100 or so.
SOURCE: just swaped cda9885 from my car to my truck, there
try pressing the reset switch. it should be a small pencil tip sized indentation on the front of the face. it will not be marked.
When operating, errors happen. Turn off the device.
(To turn off, press and hold the power button on the front
of the device for 10 seconds.)
After turning off, press the Open button and remove the
disc from the device
If needed reset the device to its factory settings after the disc is ejected. To reset it to factory settings:
Press the [UP] and [DOWN] buttons on
your DVD recorder simultaneously
when the power is on. All settings
including the password will revert to
the factory settings. Do not use this
unless absolutely necessary.
(Note that this function is possible only
when no disc is inserted.)
ok.
