SOURCE: I have a Casio Shock Risist watch (GW-500A) that
this watch requires no battery. It uses solar cells. my watch did this as well. to make the watch functional again my advice is to not wear the watch for one day and place it near a window that gets a lot of sun.
SOURCE: casio g-shock gw-330a watch. I saw the utube
http://world.casio.com/wat/download/en/manual/
There are so many aplications use of the manual will be manditory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
SOURCE: need to replace casio atomic solar watch 2608 gw-300
Check out this YouTube video which walks you through the battery change process:
http://www.youtube.com/watch?v=ogCz2vjUKVg
SOURCE: I have a gw-500a and
You have to reset this watch after battery replacement. Using tweezers or something similar you have to touch the AC & - contact on back of watch, for 2 seconds. Hope this helps.
SOURCE: setting daylight savings time on
From the main time display, hold down the adjust button until it beeps and your time zone is flashing on the bottom of the display. Then press the mode button once. [AUTO/ON/OFF] DST will be flashing on the bottom. Use the Time Memo and/or Receive buttons to cycle the mode. When it's what you want, press adjust twice.
