Kyocera Copystar Fax System M Km-5050 Km-4050 Km-3050 Logo
Khalid Mirza Posted on Aug 24, 2014
Error cfb30 when i on the copier after running error appear cfb30.i want ask how clear this code and how to go in simulation?
Duane Denis
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 08, 2015
 Duane Denis
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1047
Points
5
Try upgrading the latest firmware
Testimonial: "Sir Where i can get firware?"
How do clear H4 error code on Sharp Copier arm256
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How do I fix error code C-6 with a KM 2020 copy machine
It is resettable to enter simulation so .....
Press and let down "Clear / Stop", "Start" button on the left to darken or clear, then "Stop / Clear" "U163", "Start" appears "CLE" and there you hit "Start" other time and now.
I got 733 code so what is next procedure for copier
just try to reset that error enter to simulation press *, 2&8 simultaniously, * then select copier then select function then clear then error then press ok then switch the power off & on if the trouble appears again replace the dc controller board
SharpMX-M620N copier problem is service F2print on the display board what is that problem
F2 error code means your toner control sensor is open. i would check your toner cartridges and make sure they are all seated in the machine. Once you check all of them, turn off the machine, then turn back on. If it is still not cleared, try pressing the #, *, C,* keys in rapid succession, which will take you to the simulation mode.
once you are in the simulation mode, press 14 (for the main code) and press the start key. It will ask you to verify, say yes, then when it is finished, press the CA or "clear all" key which will restart your copy machine and hopefully get rid of the error message.
If the machine still has the error code, call a service technician to come and take a look at it.
Thanks!
Ryan
15helpful
2answers
Error code H5-01 sharp MX2300N
pascale_algu
Its a cause by continuous misfeeding. You better find the cause of that problem.
to cancel the code press program key(P), asterisks, clear key, program key . when the stand by for simulation code appears type 14 to cancel the trouble code.
Good Luck
7helpful
Error code U2 on a AR201 copier
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
U2-40 CRUM communication error
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode.
Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
3answers
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
ERROR UF-
I can help you, but what kind of copier is it? What make and model?
5answers
Cant enter simulation in sharp ar m207
Is that the right sequence for your model? The Sharp copiers I used to work on used either "CROP" (Clear, Reset, '0', Print) or "CPOP" (Clear, Print, '0', Print). I believe Reset and Interrupt is the same key.
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
