Red light blinks for about 30seconds when plugged in. after that it will blink each time I press a button on the remote.. screen does not come on or even flicker. and no sound.
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
SOURCE: lamp out maybe
my tv did the same thing and since I was getting it to work most of the time I didn't do anything until the lamp went out alltogether. If you also get a warning that your lamp needs to be replaced, you better get one. You can get them pretty cheap on EBay and on the web if you google them. Approx. $140 if you search maybe less. From Panasonic it is over $550. It was easy to replace but still cant get the lamp timer meter to reset in mine. Good luck with itl.
SOURCE: No Picture or sound
The lamp cover door was not secured tightly. Door does not "push" shut easily. Got a little rough with it and latched it shut, then the tv worked fine.
SOURCE: Set will not power on.. Blinks red LED 8 times
It's a power supply related problem.
The flashing 8 times is a trouble code. A Service Manual for your TV model will have the info on the codes. It could be a bad capacitor or a transformer on the power supply board.If you have some electronic experience, you can find a Service Manual for your TV over the internet. Cost about under $20.
SOURCE: Red light blinking three times in a row
Service manual says 3 flashing red leds = eeprom error (main digital / video pcb).
Suggest you start by implementation of Fujitsu Service Bulletin PDP 0068-01 Main Digital pcb see:-ttp://www.eserviceinfo.com/download.php?fileid=43450
