I need the factory color code for the remote wire. Need to hook up a rockforde bass amp every site giving me a different color and I do not want to hook up the wrong wire
The amp remote is actually run by the computer bus line. This is a twisted pair of wires that allow computers to talk back and forth.. therefore it does not have a remote wire. Best bet is to run amp on a switch or a keyed power wire for remote turn on. Also if u plan on changing stereo u will need to buy a interface kit or truck may not even run
SOURCE: check engine light
oil pressure too low...it must remain above 23.2 psi for the multi displacement system to work...it could be any thing from low or incorrect oil to a powertrain controller..you may need the dealerships help
SOURCE: I need color codes
Here u go, please rate this info
1996 Dodge Intrepid Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Black/Yellow
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Pink
Car Stereo Antenna Trigger: Orange/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
SOURCE: I need a diagram for the serpentine belt on a 2002
get a hane repair manul it should have a diagram in it .you can get one at the auto parts store
SOURCE: 2004 dodge ram 1500 slt wiring diagram for hooking
Try http://www.etrailer.com/faq-wiring.aspx. If it is factory installed, there should be a plug in next to/behind the parking brake pedal... at the top. Not easy to see or get to.
SOURCE: I need routing guide for serpentine belt for 2002
HI. I have located a good diagram. Kindly follow to assist with the proper routing. Use caution when installing your belt. This is the routing for your engine specs.
