If you examine the thermostat then you must check the pressure switch and timer. Could be: pressure switch stuck in a state of full (timer by level) or stuck contacts timer and timer motor is energaized and moves forward to the next cycle. You you can not exclude a mechanical failure of timer. There are so many reasons.
Dado
SOURCE: Zanussi DE540X
rather difficult to go further remotely. could be temp sensor. another place to look is at the module - have known quite frequently dry joints at the heater output. examine it carefully
SOURCE: My Zanussi dishwasher wont run a programme
Hello Paul, The first thing to try is to clean the filters at the rear pipe(s) that connect to the main water supply. It is quite common that when the water-flow is impeded, the programs may stop with flashing lights depending on the rate/amount of blockage.
So, pull out the unit and disconnect the rear pipe and give the in-line filters(s) a good going-over. Please let me know if this does the trick...
Best Regards,
Peter...
