The battery is fully charged and the charger is in good condition with no shorts. I have had the laptop for a few years and have not had a problem with it before.
SOURCE: Dell Inspirion 1526 Laptop Battery is not charging
Sound like the battery. Take the battery out and there should be a power meter on it, press it, if there are three lights that flash, the battery is shot. Not all batteries will flash if they are worn out, but they are supposed to. Try a new battery, I believe this will coorect the issue.
SOURCE: Inspiron 8600 does not charge batteries. Power
in these case u have to take one star screwdriver. carefully remove all screws n check the battery slot is it broken. if it is , den u have to change the slot.its just the connections problem. no prob with board. so dont worry ur works again.
SOURCE: Dell Inspiron 1545 power adapter not charging machine
Just call Dell, don't take it back to Best Buy or anything (that's where I got my Inspiron 1565). They will put you through a couple troubleshooting items and decide whether it's the AC adapter went bad or if they have to replace your motherboard. It's all free since they have a 1yr hardware warranty.
SOURCE: laptop dell inspiron 1545 no power up
Hello anourkhader
When was the last time you used it, and were there any problems? To find the solution to this problem is a matter of elimination. You should check the following:
Step 1 - Power
- Try an alternative power adapter
- Try plugging in your laptop to an alternative power supply
WARNING - BEFORE PROCEEDING, PLEASE FOLLOW THE FOLLOWING SAFETY PRECAUTIONS!
1. REMOVE THE POWER ADAPTER FROM YOUR LAPTOP
2. REMOVE ALL PERIPHERALS
3. WEAR A WRIST-GROUNDING STRAP, AND CONNECT IT TO AN UNPAINTED, METAL SURFACE. IF ONE IS NOT AVAILABLE, TOUCH AN UNPAINTED METAL SURFACE TO DISCHARGE ANY STATIC FROM YOUR BODY
Step 2 - Remove and reset basic hardware items
Remove and reseat the items mentioned below in the order they're mentioned:
- AC adapter
- Battery
- Memory
- Hard drive
For instructions on how to do this, please refer to your user manual. If you no longer have it, you can download it from here: http://support.dell.com/support/edocs/systems/ins1545/
If after following the above instructions, your laptop still doesn't turn on, I would recommend that you contact Dell customer support, which you can do by following this link: http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_technical_support?
I hope this helps. Please feel free to contact me if you require further assistance.
ajblaj
You have a bad or loose DC connector on the system board:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
