Where else do you have locks? A locking glove compartment often has a separate key. The main key is supposed to open the door, open the trunk and start the vehicle. The other key is a Valet Key, the key is intended for people to give to valets to park their cars or to repair shops to use. The valet key will open the car door and start the car but will prevent someone from unlocking the glove box or the trunk.
Moral of the story, never open the trunk and put the keys down. Put them between your knees or your thighs if you need two hands. I guarantee you won't do it again. Good luck. Let me know how you get on please.
if the lock , is locked ? push in the door and then try.
is it the locking kind with a key? if yes, drill out the key slot and remove the tumbler and it will open,.
some more fancy models have key option.
That key wont do anyting but allow TSA to open that lock. You cannot get that key because it is a master key that opens all those locks and it is restricted.
Programming When Key batteries completely discharged. Key batteries not replaced within 60 seconds. Key added or replaced. DO NOT press remote control buttons during battery replacement. How Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button Fig. 1 [1]. Press lock button Fig. 1 [2] briefly 3 times within 10 seconds keeping unlock button [1] depressed. Release unlock button Fig. 1 [1]. Some models: LED Fig. 1 [3] flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Some models: Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously
To change batteries remove panel back of key then screws on plastic bar
Batteries are available from your local motor factor shop
You might not need new batteries try re programing as described above
central locking on my 93 corsa with standard key, not electronic type as used on later models, all doors are locked and refuse to open, ive checked fuse and thats ok, doors refuse to open from inside the vehicle and from outside, only the tailgate will open from the key, any ideas ,,, thanks dave
dont blame the idiot,we all make stupid mistakes without thinking and iam no exception,remove door trim and oil the solonoid with a oil can not a silly sunday mechanic spray and let it soak in as its working but i think its just a bit sticky with wear and dirt ingress hence it locks but doesnt unlock which might need a bit more power,oil the whole lot lock and all
