Can open my trunk doesn't work with remote or from inside of glove compartment thanks 2005 ssr chevorlet
Rear Compartment Lid
The rear compartment lid can be opened by operating the rear compartment lid release switch, located on the instrument panel, or by using the manual release located on the rear compartment lid. Battery voltage is supplied to the rear compartment lid release relay through the Main Power fuse. The roof and door module (RDM) receives the rear compartment lid release request via the rear compartment lid release switch signal circuit. The RDM grounds the rear compartment lid release relay coil when a release input is received through the instrument panel (I/P) switch. Grounding the coil causes the rear compartment lid release relay to energize, providing power to the rear compartment lid latch assembly through the rear compartment lid release actuator supply voltage circuit.
As an alternate method of operating the rear compartment, an emergency release handle is accessible from within the rear compartment. When the handle is slightly pulled, it will provide a ground for the bed cover release relay which will cause the actuator to operate and open the rear compartment lid. If the handle is pulled further, it will mechanically open the lid, so even if the battery is discharged or there is an electrical concern, the emergency release handle will mechanically open the lid.
