TRIMMER WILL START, RUN AT HIGH THROTTLE ONLY FOR A FEW SECONDS AND THEN DIE, CAN DO THIS REPEATEDLY. WILL NOT START AND IDLE.
I've tried all of the suggestions for the problem of, runs full speed for 10 seconds then dies like fuel starved or switch cut off. Put knew carb, coil, everything. Then I saw a post here that mentioned rerouting the coil spark plug wire. It worked. I will put electric resistance cover tape and glass tape then route normal and see what happens. If it still has problem, I'll reroute permanently outside of case.
You need to adjust your idle screws. Start at 1 and a half turns out for High and Low then go from there.
SOURCE: I have a 128ld it
Hi gberrier...
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of trimmers.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil mix if your using a two cycle weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me thumbs up
SOURCE: i need a owner user operating instruction manual
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_545196750.pdf
here is a link to the pdf file to huskies website hope this helps, you can print off some or all of the owners manual free of charge.
SOURCE: Husqvarna 323L Line Trimmer - Runs for about 5-10 seconds,
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwillneed to disassemble the carburetor and spray with carb.cleaner.Makesure the small screen is free of debris. (Should be able to seedaylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
SOURCE: No Spark - Husqvarna 125R Trimmer
Check the wire that goes to the "OFF" button. See if it is by chance loose or cracked allowing a short. Beyond that, it would probably be the coil, but I would lean towards some type of a short, especially if you know the plug is OK.
SOURCE: My Husqvarna 128ld trimmer will run but only at
guys,
the d shaped tool is also carried as an MTD part. see your local dealer.
If not google walbro d cut tool ad see what you get. They're on solo
chainsaws as well
