Question about Diesel Watches
CROWN FOR DIESEL WATCH MODEL DZ-7246
NEED CROWN FOR MODEL NO DZ-7246 WHEN WATCH ON WRIST THE CROWN ON RIGHT SIDE CLOSEST TOFINGERS
    Top Expert:
  • Diesel Master
  • 66,504 Answers
Take it to a watch shop
Posted on Feb 28, 2015
5 Suggested Answers
jamil soomro
SOURCE: instruction manual required for diesel watch DZ 7033
i have found the solution by visiting this site
http://store.dieseltimeframes.com/text/content/diesel/DieselENGLISH.pdf
All diesel watches manual instructions or (guide)
jamil soomro
toronto
Posted on Mar 12, 2008
Anonymous
SOURCE: Instruction Manual for DZ-7087
hey..i found out how to set the time for the model: diesel dz7087..
all u have to do is press and hold the light button..the when it starts ticking press the mode button repeatedly to set the time,date,etc...when u finished setting everything press the light button and everything will be set..
ciao ciao
Posted on Feb 04, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: looking for a watch strap for the (DZ - 7043)
Follow this link and contact DIESEL: http://store.dieseltimeframes.com/webapp/wcs/stores/servlet/ContentView?langId=-1&storeId=33053&catalogId=21503&page=contactUs Rate me, plz.
Posted on Mar 25, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: I need a user manual for my wrist watch Diesel
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all DIESEL watch manuals. Rate me, please .
Posted on Apr 09, 2010
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: need to buy a replacement for diesel watch dz
mcdevito75 here, Best Bet is to look for a small watch repair shop in your area for the new strap.
Posted on Oct 23, 2010
How do i set the date on the diesel dz-1216
two possible methods
1/ pull crown out to first stop rotate clockwise for date and anti clock wise for day.
2/ pull crown out fully to start moving hands rotate hands through twelve O'clock twice for each day to move when at the correct day set the time then pull crown out to first stop to adjust the date, push crown in fully when done.
Mar 03, 2015 | Diesel Strap DZ1216 WW Watch for Men
I have a diesel watch model dz-2136 I need to know how to remove stem
Thank you for contacting FixYa.
I dont know why you want to remove the stem but here you go.
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder. Now you can remove the stem as described above
Aug 26, 2010 | Diesel Audio Diesel Watch
I need a user manual for my wrist watch Diesel DZ-7044
Apr 08, 2010 | Diesel DZ7044 Watch
How do i set time back and have watch work again
This model has a pull out crown (the middle "button") on the side of your watch. Simply pull the crown out and turn to set the time. If your watch is not working after this then it likely needs a battery change.
Nov 03, 2009 | Bulova 96R19 Wrist Watch
ciao ciao
Sep 09, 2008 | Diesel Audio Diesel Watch
Pulsar Men's analog wrist watch - how to set day and date
Pull crown out to 1st position....Turning one way will alter the date and turning the other way will alter the day.
Apr 23, 2008 | Pulsar PXF106 Wrist Watch
Instruction manual required for diesel watch DZ 7033
jamil soomro
toronto
Mar 02, 2008 | Diesel Audio Diesel Watch
Watches Logo
224 people viewed this question
Top Diesel Watches Experts
Janelle Schoonover
Janelle Schoonover
randymanfive
Colin Stickland
Colin Stickland
Are you a Diesel Watch Expert? Answer questions, earn points and help others
