Canon PowerShot A560 Digital Camera Logo
Dianna Lytsell Posted on Aug 22, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon customer dropped it in the ocean any chance of getting it to work again
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on Aug 22, 2014
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444093
Points
622693
Maybe.
Did you fish it out immediately, removed the batteries, rinsed it in fresh water, then let it dry thoroughly before even thinking about trying to turn it on? If so, it MIGHT work again after being dried. Otherwise you may as well give it a good funeral and get a new camera.
I can't find the IP address for my MX330 Canon printer. I'm trying to print from an Android Galaxy tablet using a USB cable and am asked for the IP address to print.
In the event that you don't approach the Canon printer or on the off chance that you would prefer not to look through the menu framework, discover the canon printer IP address on any PC on which the printer is set up.
FOR WINDOWS
Open Control Panel > Devices and Printers. Right-click the printer and select Properties.
One of two arrangements of tabs shows, contingent upon the kind of association the canon printer driver employments. In the event that the Canon printer is set up under a WSD port, it uses Web Services for Devices innovation to associate with the printer. For this situation, select the Web Services tab to see the printer IP address recorded in the IP address field.
On the off chance that you don't see a Web Services tab, at that point the Canon printer is set up utilizing a TCP/IP port. For this situation, discover the IP address in Printer Properties.
1. In Control Panel, pick Devices and Printers.
2. Right-click the printer and select Properties.
3. Select the Ports tab. The IP address is shown in the Port field.
Port tab of printer Properties with IP address
4. On the off chance that you don't see the IP address, select Configure Port to see the IP address arranged for that printer.
Intex Challenger K1 Rudder
No rudder system is available for INFLATABLE kayaks. They are no good for oceans or lakes only a swimming pool. Get a good solid Ocean Kayak or other brand that is RIGID. Your life may depend on it.
When I turn on my canon camera it says Lens error restart camera, what do I do? How do I restart my camera?
"restart camera" just means turn it off and on again. Have you dropped it by any chance? If you have a lens that telescopes out and you dropped it, it's probably not aligned properly anymore. You probably need to take it in to get fixed - which can get pricey, unfortunately.
I dropped my sony cybershot in the ocean... i am okay if it doens't work again but i want to get my pictures off the digital memory...any way that can happen?
If the memory card has sufficiently dried out and the contacts have been wiped clean with a soft cloth, you can use a card reader to download the pics to your computer.
1helpful
3answers
Dropped into the Atlantic Ocean. Can the camera be repaired too operate again
everything can usually be repaired for a price. But saltwater absorption will lead to eventual corrosision no matter what you do. Cheaper to buy a new camera
Sep 01, 2009 • Cameras
1helpful
Lens error. Restart camera.
this is very common has the camera been near the ocean??? it does not have to be dropped to give you this error. repair on you lens runs 85.00 for repair. or a new lens for 125.00
2helpful
Canon SD1000 blurred pictures and blurred LCD, Camera wont focus! please help ive had it for 2 weeks
The best chance to use your SD1000 is to set to picture, push ISO (on top of the func. set ring) and set to hi. This works pretty well. Do not bother sending any camera to Canon, they charge the "standard charge" plus for all their manufacturing problems on all Canon cameras. Definately the worst customer service on the market.
Date/Time Set Won't Work
Write to Canon's customer service. I dropped my camera in water briefly and wrote them. They offered me the chance to replace my camera at an outstanding price or have it repaired. Give them a try!
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
