Salter 2001 electronic kitchen scale Logo
R
Rosemary Knowles Posted on Aug 22, 2014
Changed batteries CR2032 and now "ON" appears but will not weigh an object in grams or ounces.
Will turn itself off.
1 Related Answer
Thomas Beaver
  • 2119 Answers
  • Posted on Aug 22, 2014
SOURCE: Why will my scale not weigh an object?
Salter Salter global
Wha is 375gms of flour equal to in australia
375 / 120 = 3.125 or 3 and 1/8th cups (2 tbs) https://www.kingarthurflour.com/learn/ingredient-weight-chart.html For best results, we recommend weighing your ingredients with a digital scale. A cup of all-purpose flour weighs 4 1/4 ounces or 120 grams. This chart is a quick reference for volume, ounces, and grams equivalencies for common ingredients.
2answers
How many grams are in 50.7 fluid oz?
Gram is a measure of weight (or mass). Fluid ounce is a measure of volume. There is no direct conversion between them, since it depends on the density.
For example, 50.7 fluid ounces of molten lead will weigh considerably more then 50.7 fluid ounces of water.
3answers
Weight of a gram of sunflower seeds
A gram of sunflower seeds weighs exactly one gram or one-thousandth of a kilogram.
If you want the Imperial equivalent there is about 28 grams to the ounce so one gram will equal one twenty-eighth of an ounce.
Measuring such small weights requires a different measuring scale and the apothecary measures are appropriate: the dram is one sixteenth of an ounce.
For rough measure purposes one gram is about a quarter of a dram.
For exact purposes all the conversions can be found by google.
For practical purposes it would be better to measure out one ounce, one half-ounce or one quarter-ounce of seed whichever can be done most accurately and then divide it by eye into 28, 14 or 7 equal portions in order to obtain approximately one gram.
If greater accuracy a chemical balance would be required.
Feb 26, 2015 • Birds
5helpful
Have a Chefmate digital stainless steel scale. It weighs in grams and ounces. It was changed accidently to grams but I want it in ounces. Not sure how to do it and misplaced owner's manual.
Easy! On my Chefmate scale what I have to do is toggle so that "weight" is blinking. Then hit "0" - that is zero. Now you can change back and forth from grams to oz!
2helpful
How many grams are in a ounce
There are approximately 28.35 gm (grams) of the metric system in one oz (ounce) of the British Imperial and US Standards for weights and measures.
Also:
1 avoirdupois ounce = 28.35 gm 1 troy ounce = 31.10 gm (Troy ounces are used for weighing gold, and other precious metals.)
1 fluid ounce = 29.57 ml
3helpful
2answers
ONE TROY OUNCE EQUALS HOW MANY CUBIC INCHES? Another way - how large is a troy ounce of gold?
1 troy ounce =31.1035 grams
454 grams = 1 lb
gold weighs .3091 lbs/cubic in
therefore 1 troy oz = 0.2216 cu in
Top Salter Health & Beauty Experts
vince
jws1013
Ngoro
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
