The battery will have a number on it when you open the case. Get a flashlight to look at if lighting isn't good, otherwise when you find the number, you just buy one with the same number. It's a button/coin type battery that you can buy at most stores.
It should be button type cell CR2032, common type used for PC motherboards.
SOURCE: What type of CMOS battery do I need for Optiplex
CR2032 battery, located on the motherboard here,
http://support.dell.com/support/edocs/systems/opsx270/en/ug/battery.htm#1095363
Testimonial: "Thanks for the quick response!"
SOURCE: Dell OptiPlex GX620 starts up then shuts down repeatedly
Try this: remove the DMOS battery and unplug the on/off switch plug. It's the one in the corner near the power supply. To be sure follow the cable from the front on/off switch board on back to this plug. Then plug the A/C cord in, if the system boots up fine, then replace the front panel power on/off swith board. Naturally you will not be able to power off the computer using the power switch (since we unplugged it), so you will have to just pull the plug. Hope this helps. Joe
SOURCE: i need video and adudio driver for dell optiplex
Here is the link for your drivers, just select your OS;
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=PLX_GX620
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
