Everything works except the fan on the inside of the microwave. Can this fan be replaced?
Hey friend, that's a great question!
Based off the information you have provided the fan inside your Frigidaire microwave, FMV156DC, can be replaced. I would suggest contacting a professional because some of these intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I suggest seeking assistance. One must be very careful as these replacements can lead to potential harm. -Matt
SOURCE: Microwave Oven Does Not Start Cooking
This
is usually caused by either a bad door switch or a loose door switch
mount, which are pretty simple problems to fix.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
One test that sometimes
helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount
or
door alignment issue.
If you or someone you
know decide to look
into it, we have critical information on safety, disassembly and door
switches at our site, and our link is at our listing here on
FixYa:.
You can find helpful
exploded view diagrams and order parts by entering your full model
number here.
There should also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very
helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a
switch, you can order a universal type here for $5 postpaid.
If you think the problem
is on the control panel, we repair these nationwide by mail
for $39.95 postpaid in most cases in about a week or so.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: Everything works except the microwave function
yes there are fuses inside it,,,but,,,there is also a lot of volts still in it too, "ie, 1000's" and they bite too,
bit like a police stun gun will,,but they may not just stun you,,they could very well kill you,, so be warned!
also the fuses are not the normal sizes you would have at home, and some of them are "slow blow" type and some are "fast blow" type,,, and one is at least 1 to 4 1000 volts type?
and my gess is a fuse has poped becouse the magnatron has given up the ghost and poped its clogs!!! like its dead! and a new magnatron would be dearer than a new microwave to have fitted,,
so,,,get a new unit,,dont tinker with it and stay alive!
SOURCE: Less than 5 years old
That pop was the magnetron frying. This is a repairable problem, but feirly expensive, around $300 if you have it done by a professional.
Please rate my response if it was helpful to you.
Thanks, Repairman45.
Testimonial: "Quick and accurate! Will go ahead and replace the entire unit. Thanks REPAIRMAN45!"
SOURCE: Everything on my microwave is
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html Now keeping clear of the microwave, switch on, use a cup of water inside to test. Thank You for using FIXYA.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.Check the cost of a magnetron and estimate, wave gguides cost less and it is worth replacing.
If there is heating without any issues, you can use the microwave safely
