estart the printer: Turn off the printer, wait a few seconds, and then turn it back on.
Update the firmware: Check the Xerox website for any available firmware updates for your printer model. If an update is available, follow the instructions to download and install the update.
Perform a firmware reset: Contact Xerox support to perform a firmware reset, if needed.
Error 386: This error message typically indicates a problem with the printer's communication interface. To resolve this error, try the following steps:
Restart the printer: Turn off the printer, wait a few seconds, and then turn it back on.
Check the cable connections: Make sure that the cable connecting the printer to the computer is securely connected at both ends.
Try a different cable: If the cable connections are fine, try using a different cable to connect the printer to the computer.
Check the computer settings: Make sure that the computer is set up to communicate with the printer correctly.
If the error persists after trying these steps, I would recommend contacting Xerox support
1-800-835-6100
Call: 1-800-835-6100. Xerox offers a robust set of self-service solutions through our online knowledge system, YouTube Video site and community forum discussion boards to assist in resolving problems Customers may encounter with their Xerox device, regardless of device warranty or contract.
There is a bulletin from Xerox that helps to troubleshoot and identify the error. If you provide me your e-mail address I will send it to you. Please e-mail me at [email protected].
SYSTEM NEED TO BE RESET, CARTRIDGE MAYBE DEFECTICE, THE SWITCH MAYBE A PROBLEM, GO ONE LINE AND SEE IF ANYONE ELSE SEEN THESE TYPES OF PROBLEMS, GO ONLINE AND TYPE:
XEROX PHASER 5500N LASER PRINTER CARTRIDGE ERROR 11ER00670
ENTER
IF THAT WAS THE ERROR NUMBER YOU HAD
OR
XEROX PHASER 5500N LAZER PRINTER CARTRIDGE ERRORS
ENTER
OR
XEROX FOREM GROUP
ENTER
OR
MANUFACTURE NAME,MAKE,MODEL, DRIVERS AND SERVICE MANUAL
ENTER
I found a couple of references to the error ?07,010.43?, it?s a generic message with lots of possible causes. Xerox?s official web site says to turn your printer off a contact their technical support.
I did find one reference that said for them it turned out to be a wiper assembly stuck between the print head and the roller. I?ve never owned a Xerox printer (I?m an HP guy) so I can?t help you beyond that. Xerox?s support site for the phaser series is here: http://www.office.xerox.com/color-printers/phaser-8500-8550/sprt-enus.html
