E4094
The problem is which ones connect to which ones ?
The only time a motherboard manual is provided to the user if when the you:
PC manufacturers usually purchase customized versions of commercially available motherboards for the machines. They specify chipset parameters and BIOS contents specific to the build(s) they plan to create.
Because of that, it is not usually possible to obtain a motherboard manual for such machines.
SOURCE: can't find wher can i fix the restart and the led bottons in the motherboard
There should be two rows of metal pins on the motherboard. The pins are about 5mm tall and have white letters printed near them on the motherboard. HDD PWR RST SPKR You connect your wires coming from the lights and switches at the front of the computer to these pins.
