Will not print, getting a window showing a preview failure
Reinstall drivers. HP LaserJet Pro 200 color Printer M251n Drivers
SOURCE: Print Cartridge Alignment Failure
two option:-
1. cartridge is not proper. or
2. not proper installed.
SOURCE: Printer Error
Go to control panel>printers & faxes. Open the printer, go to the top of the tool bar>printer>properties>align cartridge.
SOURCE: My hp officejet J4680c printer and my hp pcs 1315
follo0w the link to avey for further help
http://www.avery.com/avery/en_us/Help-Center/Formatting-and-Printing-Tips/_/Ns=Rank
SOURCE: does not print in color
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
Testimonial: "I would love to think the problem was that simple, but the test paper came out fine. The print preview is in color, but it prints black and white"
SOURCE: printer will not print
please understand that this is an issue with the printer hardware and not the cartridges.so dont waste ur money purchasing new in cartridges hence refer to this document
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00723815&cc=us&lc=en&dlc=en&product=1153494
