SOURCE: no response from amp
They go into protect for several reasons. Unless you are a trained technician you should not try to repair it yourself. It may have a blown channel. Disconnect the speakers and try turing it on again. If it still goes into protect you have a serious problem. If it does not go into protect, you may just have a bad speaker, or have the impeadance too low for that amp. The smartest thing to do would be to take it to a repair center and have them test it to find out if the problem is in the amp or in the wiring/speakers.
SOURCE: the amp light turns red
it is probably a bad ground, but maybe not, but maybe.......hope this helps
SOURCE: red light
no i think the subs are blown because subs blown send transitor sound back to the amp
