SOURCE: times of day clock stopped
you are experiecing with your CMOS battery so:
try taking the CMOS battery out
leaving for 30 seconds
make sure it's all unplugged from the wall
do that first
then press the power button after the 30 seconds
to drain all power
then put battery back in
and plug in and turn on
and if still problem remains then you need to change your CMOS battery.
Thanks and do not forget to rate answers.
2 Press the PLAY [UP]or STOP [DOWN] button to select INITIAL
SET UP, then press the FF /OK button.
3Press the PLAY [UP] or STOP [DOWN] button to select CLOCK,
4Press the PLAY [UP] or STOP {DOWN] button repeatedly to set
the TIME. Every time you press the PLAY [UP] or STOP [DOWN] button,
the time changes in one-minute increments. If you press and hold
the PLAY {UP] or STOP [DOWN]9 button, the time changes in 30-minute
increments
5Press the PLAY [UP] or STOP [DOWN] button repeatedly to set
the DATE (month and day). Every time you press the PLAY
[UP] or STOP [DOWN] button, the day changes in one-day increments. If
you press and hold the PLAY [UP] or STOP [DOWN] button, the day
changes in 15-day increments.
When the month and day are correct, press the FF /OK
button
6Press the PLAY [UP] or STOP [DOWN] button repeatedly to set
the YEAR. When the year is correct, press the FF /OK
button. The day of the week will appear automatically
7Press the FF /OK button once again to skip "AUTO
CLOCK" and go to "D.S.T." (Daylight Savings Time).
Press the PLAY [UP] or STOP [DOWN] button to set D.S.T. to ON
or OFF. If AUTO CLOCK is OFF, you may set D.S.T. to ON or
OFF only
8Press the EXIT/STATUS button
