4L60E/700R4 Transmission Pan 82-97 Chevy & GMC Truck / Logo
A
Anonymous Posted on Aug 21, 2014
4l60e transmission will not shift back to first all the time after I stop. tries to take off in second.i can manually shift it into first. how to fix?
2000 chevy siverado 4l60e transmission after stopped will sometimes not shift down to 1st. it tries to take off in 2nd. have to manually shift to 1st then back to drive. how to fix
Tom
Level 2:
Sergeant:
  • Expert 314 Answers
  • Posted on Aug 24, 2014
Tom
Expert
Level 2:
Sergeant:
Answers
314
Questions
Helped
174517
Points
682
An electronically shifted transmission. Sounds like a sticking solenoid that controls 1st gear selection. If it isn't located inside the pan (some are) you can remove and clean it out or replace it. If inside then I would take it to the dealer. They know these vehicles and have seen just about everything that can need attention in them.
1helpful
3answers
I have a 2005 Chevy Tahoe a when I bought it off a friend it was running good then one day it decided to not want to shift gear. Does this just mean I just have bad silinods
check fluid level and condition ---have scanned for any trouble codes -----can be anything from tcm --to 4wd problems need to have diagnosed not just guess about a part
1999 k1500 4l60E with push button 4wd
bad VSS (chevy) k1500 not Suburan. 4th gear dead.
NOT TOLD ALL 4wd or 2wd truck, and matters huge on VSS.
5.0L? no car mileage told or on tranny..
the scan tool tells you VSS is dead.,veh.speed,sensor.
the transmission shifts by lots of variables and FOR SURE SPEED, is one, so the would't cause is dead wrong;.
first thing to do is learn what box is there. (real name)
GM car is GM transmissions sure but which exact one.
and why do you ignore the speedo/tacho, they must work.
chevy 1999 k1500 4L60E RPO Codes M30
4L60e electrically shifted by the TCM brain (it or PCM/TCM)_
to shift electronically many things most work
VSS, and all speed sensors, and shift solenoids.
and more this code smacks of cam timing errors top me.
Trouble Code: P1345 (5.0L V8 VIN M Auto)
Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation( < this word means OUT OF TIME in geek speak) the PCM predicts next cam pulse and is way the heck off time, and tells you it is and does not lie. OMG it has an old Distributor and CMP is bad or distributor ws never timed correctly as the SM directs.
SM= service manual.
this error can not be ignored, but back to transmission problem in drive
To shift up the TCM brain must know speed
in drive upshifts fail, hard.
I am reading your SM now. learning what version this 4L60 is
and all sensors and if it has line pressure control solenoid.
to get the VSS DTC error one must drive long time to get it.
but the speedo did not lie to you , VSS is dead.
yes it has PCsol PCS solenoid that sets main tranny line pressure just before the shift, ( 3 soles to shift , not 2)
as you go higher gears the main line pressure needed to do so needs lots more pressure
from 75PSI to 175 PSI in drive. if not gears fail.
now 2 photo to prove all this.
first is VSS then 2nd is PCsol.
1helpful
A 4l60e transmission how do I no if i have a bad 3-2 downshift sol on a 1994 chevy Pick up
Albert, Have truck scanned for trouble codes. To test a transmission solenoid, use hand held ohm meter. Instructions in second link below, the attached links are informative on the different procedures used to test solenoids.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test shift solenoid 4L60E
http://etereman.com/blog/general-motors-transmission/how-to-diagnose-a-bad-solenoid-in-your-4l60e-transmission
Shift Solenoid and Tests GM 4 3L 5 0L 5 7L
How Can Tell If My 4L60 Transmission is BAD
How do I fix automatic transmition in 2002 GMC ENVOY 4x4 shifts hard into third will not shift into overdrive already replaced the two solenoids in front before it would not shift to third
How To Rebuild A 4L60E Automatic Transmission - YouTube
? 13:19
https://www.youtube.com/watch?v=JpmJtuVrdWk
Mar 16, 2011 - Uploaded by Nick Stageberg
How To Rebuild A 4L60E Automatic Transmission ... Also here is a link to some common break/fixes that may require a rebuild:... GMC canyon, envoy, safari savana, sierra Sonoma, Yukon, ....Great video, my 96 sierra 4x4 when shifting into high gear motor races as if nothing is there........................always ...
30 Common 4L60E Transmission Problems & Repair ...
www.twincharlotte.com/transmission-repair.../30-Common-4L60E-Trans...
Mar 18, 2011 - The 4L60-E is an automatic shift, four-speed overdrive, longitudinally...... 4l60e 2002 gmc 4x4 was not driven for 1 year,will not shift into 3rd or ... I have a 2005 GMC envoy 4x4 6 Cylinder I assume it is a 460LE Transmission.
Transmission will only shift in 4 low,no codes showing
1994 GMC 4l60e transmission shifting problems - CarGurus
www.cargurus.com > Questions > GMC > Sierra 1500
CarGurusJan 17, 2011 - 1994 GMC 4l60e transmission shifting problems - I've got a 1994 GMC Sierra 4X4 5.7 I ... If you put it in low and lift the handle, it will go into second .... Justchange 1-2 - 3-4 solenoids first and if that doesn't work change the ...
Troubleshoot automatic transmission problems
www.2carpros.com/articles/automatic-transmission-problems
Jul 15, 2015 - Rescan the PCM for trouble codes, if none appear the problem could ...Excessively low transmission fluid (Note: If transmission is operated for an .... it waslow, and now my car will only shift from 1st to 2nd manually and will ...
Transmission troubleshooting 4l60e at times valve body must be opened manually by pulling into low gear after coming to a complete stop when at operating temprature
Could be the ladder. If I were you. Id check the throttle position sensor, also.if equiped the idle air speed control motor.
3helpful
5answers
1997 Chevy 4L60e Transmission Shift Problem
How many miles? Have you maintained, serviced trans in past or just waited for this day to wonder what happened?
3helpful
2answers
95 GMC Sierra 4L60E will not shift down to 1st or up to 4th.
no power stuck in 3rd gear electric shop unless youve burnt it up good luck...www.TransmissionGarage.com
Transmission doesnt seem to engage, no drive indicator on column
I would take it back to the person that rebuilt it and make them fix it again or get your money back if you can
Top Mag Hytec Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Mag Hytec Vehicle Part and Accessory Expert? Answer questions, earn points and help others
