Question about Epson Stylus NX400 InkJet Printer
Put in new cartrige but o take it out to clean the heads manually but then when I reinserted the brand new cartriget says i empty & ds to be replaced.
SOURCE: epson stylus color 760 failing to print.
you can take it to repair shop and they will clean the head for you with some cleaning fluid if it has been without ink for a while sometimes these get blocked but it is not worth replacing cus would cost more than the printer as the ink cartridge you brought was originall then this isnt the problem check all cables if not better off buying new printer as these are not made to last long sorry couldnt be any,more help...........................
Posted on Nov 05, 2007
SOURCE: Status Monitor says ALL ink cartridges empty
Using recycled ink cartridges in your inkjet printer is never a more economical way to do colour printing, unless you are willing to become a master technician on your particular product and have ready access to print heads and machine engine unit replacements, you will also need manufactures service software/website to reset waste counters/error codes.
It is expensive to print in colour full stop. Printing cost is at least 30cents inkjet and 10cents toner/laser per sheet
Laser b/w and colour is far cheaper per sheet, but setup costs are one time expensive but they are also a lot more reliable printing system.
Your machine will stuff up sooner rather than later when using non genuine consumable, and when it does it will cost more than the machines worth to even look for repair, so be prepared if choosing this road to purchasing a new printer every few cartridges if you are lucky.
If your using non genuine products and you want machine looked at by a professional the first thing you will need to do is install all genuine products in to your machine to allow correct fault diagnostics to be done, this is before any repair cost that maybe incurred.
Recycled/refills/aftermarket ink cartridge faults include – not recognizing ink, poor print quality, error codes, wont come to ready, erratic carriage movement, lines, waste counter issues and also paper feed problems, circuit board/connection faults caused by leaked ink .Not all faults are immediately apparent it takes time for the poison ink to replace that in the supply system then issues begin.
Cheap printing can be achieved using b/w lasers they cost less than 2 cent per sheet and have a brilliant reputation for print quality and dependability. Then if you need the occasional colour go to the shop, let them have the hassle, stress, time and expense of running the machines and the cost is still relatively cheap to you.
There are many consumers still printing with 10 year old laser machines, you would be extremely lucky to find a 3-5 year old inkjet.
If you must recycle well buy one that has already been proven to be adaptable to the concept, so that means go back to older units that went so clever.
Older Lexmarks, Epsons and HP were once easy targets, there was and is a lot of development gone into managing bulk ink deleivery systems, software has been cracked and parts can be sourced.
Inkmizer canon/epson bulk ink modified printers
Chipresetter be prepared for some frustrations and mess.
P.s. Most new machines come with starter inks that do not contain as much as new ones ussally 3ml instead of 5ml to enable cheaper selling cost, but also note that about 2ml of ink is in the tubes that run from ink carts to print head.
Posted on Dec 22, 2007
SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Posted on Jun 17, 2008
SOURCE: Epson Stylus DX8400 empty ink cartridges but actually new
Sometimes there is a coating on the chips (even original epson ones!) - Old wives tales say dont touch the chips with your fingers - but take the carts out one by one and wipe your finger over the chips (1 finger for one chip - dont reuse the same finger on a different chip)
Reinstall them and that worked for me on a dx4500 with original epson carts in
Posted on Dec 29, 2008
SOURCE: "Ink cartridges cannot be recognized" when using genuine Epson
i had this happen to me twice with two different people, it is highly possible that your black inks are defective, its also highly possible that one of the other inks are causing this error. take them all out, and put one and see what happens, do this one at a time until you see something screwey.
also possible, the contacts on the printhead are dirty or are pushed in.
also possible, bad printhead.
Posted on Jun 27, 2009
Jun 13, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Mar 19, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Feb 14, 2010 | Office Equipment & Supplies
Jun 20, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
May 22, 2009 | Dell 810 All-In-One InkJet Printer
Jan 19, 2009 | Epson Stylus Pro 9800 InkJet Printer
Dec 17, 2008 | Epson Stylus Photo 830 InkJet Printer
Dec 10, 2008 | Canon PIXMA MX310 All-In-One Printer
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Mar 25, 2007 | Epson Stylus Photo RX500 Printer
130 people viewed this question
