Kenmore 53642 / 53644 Side by Side Refrigerator Logo
Posted on Nov 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace the ice dispenser motor (part # 2252130) on a kenmore elite side by side refrigerator with the ice dispenser in the door(model # 106.57789701)? Do you access the dispenser motor from the outside of the freezer door? If so, how do you get to it? You can access the motor connector from below the ice maker but not the motor.
deton8 von Splosion
Level 3:
  • Kenmore Master 3,342 Answers
  • Posted on Nov 08, 2017
deton8 von Splosion
Kenmore Master
Level 3:
Answers
3342
Questions
6
Helped
928843
Points
54123
Hello... Love this refrigerator...
Great video from one of my FAVORITE PART-HOUSES...
FOR your part... http://www.appliancepartspros.com/whirlpool-motor-assy-dispenser-wp2252130-ap6006769.html
(good prices (usually... always shop around (+ shipping))
Hope this really does it...
ELSE comment me back I am here daily.
Carnac the Magnificent
  • deton8 von Splosion Nov 08, 2017
    Sorry.
    Straight-up ANSWER...
    Open the door... bend over and look at the two screws holding the INTERIOR plastic cover in place... (easy auger motor access).
    BUT watch the video..
    (Of course there is a SPRING atop the hex drive shaft... Just be careful. There is no need to remove that shaft)).
    EASY ACCESS... Quick job.
3 Related Answers
Anonymous
  • 14 Answers
  • Posted on Apr 04, 2009
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Anonymous
  • 36 Answers
  • Posted on Jul 24, 2009
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Anonymous
  • Posted on Jul 29, 2010
I had the same problem with our Whirlpool Gold. Which by the way was just out of warranty. The guy who repaired the problem told us that since there were so many replacement dispenser motors at different supply locations that there must be a problem. I think that the root cause is the arm in the ice holder is hard to move, and it burns the dispenser ( #2252130) motor out. Whirlpool should get to the bottom of this and offer free or reduced repairs. Motor # 2252130
2answers
Dispenser door opens, but auger motor doesn't operate for cubes or crushed ice.
I believe that voltage to the auger motor should be DC voltage. Yes it could be a relay on the board causing this and it could also be the Auger Motor 2252130
APPLIANCE 911
1helpful
Kenmore Elite side by side wont distribute ice
you may try dumping the ice and rinseing the bucket make sure door switch is closed.
3helpful
5answers
Ice dispensing motor (IDI Motor) inoperative
I had the same problem. GS6NBEXRS00 is 4 years old. Intermittently the ice dispenser would stall. Usually in crush mode, but occasionally stalled in cube mode. A sharp bang on the front of the door or the back of the ice dispenser from inside the freezer would get it working again for a short time. Went through the same steps you did. Replacing ice dispensing motor 2252130 fixed it.
2helpful
1helpful
I have a Kenmore Elite side by side refrigerator/freezer and just had the ice dispenser motor replaced a month ago when we first moved in our new house. However, our daughter left the freezer door ajar...
It would not hurt the motor as they are built to be exposed to some degree of moisture if the defrost does not work i would check and see if something is jamming the actual mech. up. In my ice dispenser i had stuff fall in from the shelf's and seized up the motor. Any how if the thaw does not work check out a motor at repairclinic.com (http://www.repairclinic.com/SSPartDetail.aspx?s=t-106.53769202-%3d%3dc203i1057785&PartID=1057785)
7helpful
3answers
1helpful
Ice does not dispense through door of kenmore elite side by side
take ice bucket out, dump ice, clean with hot water and let dry ,,,, put ice back in and try it ,,, bucket is most likely frozen up thru ports
No ice through dispenser
When you operate the ice dispenser lever, you should be able to hear a little click from a micro-switch that then switches the auger motor and the light on and also opens the flap. If you cannot hear this small click, then the micro-switch is faulty. The ice dispenser only works when the freezer door is closed, so you could also inspect the door light/fan switch for proper operation.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
