Freezer beeps; cure is a 9 volt battery. Where does it go?
SOURCE: Kenmore freezer depleting 9 volt batteries, setting off alarm
trojo50,
your defrost elements are not working or the water inlet for the evaporator tray is clogged. That alarm is to let you know something else has triggered it. This could be s imple DYI solution or require a service call. let me know if you are up for the DYI.
randy320sgi
SOURCE: Where do I install a 9 volt battery?
much better to call technician to install that if you confusing to install then observe it next time you can do it on your self
