If you're refering to the item i have highlighted then remove the driveshaft from the plastic flexible liner, clean shaft, re-grease and replace. You'll probably fing the shaft has become dry and has rubbed, causing it to get hot. The plastic liner should not be spinning in the drive tube assembly so you may need to get a new 'flexible liner' that fits snug.
