Thank you for your inquiry, friend!
I understand that you are looking for the meaning of "E15" on your Electrolux range. "E15" stands for ESEC self-test failed, which could either mean and issue within your UIB (User Interface Board) or relay board. I would recommend having a professional come out to diagnose and repair your appliance. Best of luck. -Matt
Thank you for your inquiry, Carol!
From what you have described your Electrolux range is displaying an error code of E15. I see you have reset your breaker and continue to receive the error code. The error code E15 means that your ESEC (Electronic Surface Element Control) test failed this could be a problem with your relay board or UIB (User Interface Board). When you reset your breaker did you leave it off for at least ten minutes? That is the best way to reset your range. You may need to seek assistance from a professional technician for proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Thank you for your post, friend!
From my understanding your Electrolux range is displaying an error code of "E15". An "E15" code stands for the ESEC self-test failed. This might be an issue with your ESEC (Electronic Surface Element Control) board or ESEC-UIB (User Interface Board). Before seeking any assistance with a professional technician I would advise you to perform a reset on your range. You can perform a reset by disconnecting power from your range for roughly ten minutes. If that does not help resolve your current issue I would suggest consulting with a technician for repairs. Hopefully this information is helpful. -Matt
Good Morning friend, thanks for your post!
I see your Electrolux range is displaying "E15" error code and you have reset your appliance but continue to receive the message. An "E15" error code stands for ESEC (Electronic Surface Element Control) self-test failed which could be a possible issue with your relay board or UIB (User Interface Board). I suggest seeking assistance from a technician to properly diagnose and repair your appliance to avoid any unnecessary part purchases. -Matt
