Pool & Spa Logo
A
Anonymous Posted on Aug 19, 2014
Does the onga spa master 4352 have a fuse or overload switch?
My onga spa master 4352 pump stopped working suddenly without any apparent cause. Im hoping its something simple like a blown fuse or tripped overload switch. Does this model have either? Or can you provide any troubleshooting tips I might try before I call in the repair guys?
David Spradling
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,448 Answers
  • Posted on Aug 25, 2014
David Spradling
Master
Level 3:
Renaissance:
Answers
1448
Questions
Helped
518481
Points
1901
Try to reset breaker if not blown check to see if there is a fuse after that probably a bad capacitor on motor or bad motor
5 Related Answers
Anonymous
  • Posted on Apr 19, 2009
SOURCE: High speed spa pump shuts off
The motor may have a thermal cutoff if the motor draws too much current. Do you have a sufficient large gauge circuit supplying the motore? If not the actual voltage at the motor may drop, causing it to draw more current to make up for the loss of voltage, thereby tripping the motor's protective breaker. I assume the motor will start again after serveral minutes of cooling down.
Curtis
dragonsthatk
Albert Getty
  • 547 Answers
  • Posted on Apr 20, 2009
SOURCE: pool pump not working
there would not be a fuse if this has a reset button I would suggest you return to company you got it from and have them replace the defected one thank you
please rate me
Anonymous
  • 131 Answers
  • Posted on May 18, 2009
SOURCE: Hayward Super Pump not turning on
it sounds like your pump is stack it could
bee that something is stack in the pump,
try somehow to turn the motor to see what is binding
get access thrue the pump.
G
thepool
thepool
  • 78 Answers
  • Posted on Apr 21, 2010
SOURCE: Trips GFCI outlets
The motor on this unit is sealed and not accessible for repair, only replacement.
john224
John Prohaska
  • 1378 Answers
  • Posted on Sep 21, 2010
SOURCE: I have a flo master xp2 / 48 frame / 230V / 2.5 hp
You shorted the 230 lines at the motor terminal board. If you are certain you have reset any and all breakers feeding the spa and that the 230V is getting back to the pump motor then you blew the winding leads as you shorted the motor. While it is possible a motor shop could repair the leads it is far more likely the damage caused will cause the price to be that or more of a replacement motor.
John
1helpful
My aqua drive 1100 auto reset pool pump runs warm and stops after a few seconds after i switch it on then goes on after a few minutes And this continues. Why
Thermal Overload Switch: Something is creating an overload on the pump. Once it is overworked, the motor will overheat. This will be sensed by the T.O. switch. Once the switch senses that the motor has cooled, it will start again.
Reasons for overload:
  • Bearings no longer spinning freely & without restriction
  • Foreign debris in the volute, jamming against the impeller
  • Failing T.O. switch
Good Luck
Onga 4352 Spa Pump is leaking from the opening in the bottom of the pump. I have opened it & siliconed the Oring seal but it continues to leak. Any suggestions?
I had a new pump brought to me once that continued to leak after replacing the shaft seal three times. Careful examination revealed a sand casting fault in the pump body. The water was leaking through the body of the pump. Have you replaced the shaft seal?
Nov 04, 2014 • Plumbing
Hayward RS2000 suddenly stops. Motor housing is extremely hot and has a burnt smell. Thermal overload going bad?
it sounds like there may be a short in the pump. this will cause it to overheat and trip the thermal overload. it may be time for a new pump as this is usually cheaper than fixing it
2helpful
My Onga PPP1100 pool pump cuts out every 5-10 mins then restarts after 5-10 mins.
Depending on its age, it may have been fitted with the wrong thermal overload when it was manufactured. If it is relatively new go back to your supplier for a fix; if it is not new please tell us more about the problem..
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
