GE Profile Spacemaker Over-the-Range Microwave Logo
A
Anonymous Posted on Aug 19, 2014
What do i need to replace bulb for GE Spacemaker microwave JVM3670BF10?
5 Related Answers
Anonymous
  • 625 Answers
  • Posted on Dec 29, 2007
SOURCE: replacement cooktop light bulbs
look inside for a removable panel for access to the lamps. consult your instruction manual.
Anonymous
  • 579 Answers
  • Posted on Jan 02, 2008
SOURCE: Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 16, 2008
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
vitg55
Vitaliy Gins
  • 78 Answers
  • Posted on Dec 01, 2008
SOURCE: need to replace outside door frame on ge spacemaker xl microwave
Here a few site can help you:
http://www.partselect.com/
http://www.repairclinic.com/
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Thomas F. Schneider
  • 2715 Answers
  • Posted on Dec 31, 2008
SOURCE: Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Where can i order a replacement light bulb for the ge spacemaker microwave
is this inside or under microwave most lights can get at hardware stores
GE profile spacemaker XL1800 undercabinet microwave - how do you change the 2 lightbults under the microwave. I can't get the bulbs out.
There are several screws on the bottom panel that can be removed. After you remove them, the metal plate can be removed or just lowered at an angle. Using a flashlight, you will see the two bulbs that probably need replacing. Pull the wire down, and they can be easily removed and replaced.
Hope this helps.
1helpful
GE Spacemaker Microwave lights flicker on then off
There must be a short in the wiring between the bulb sockets and the power supply or control board. Otherwise the short may be in the bulb sockets themselves.
I would test the connections to make sure the wires aren't loose and all solder joints are tight. If all wires look good, and bulb sockets are tight, then the problem may be faulty capacitor
2helpful
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, [email protected]
1helpful
2helpful
Need new light bulb socket for GE spacemaker mircrowave
The bulbs are glued in at the factory. Unplug the microwave and see if you can remove the base of the bulb from the socket with needle nose pliers. You may have to twist the heck out of the bulb base but it should come out. If you do need a new socket it is available at www.geappliances.com under parts and accessories. Or call 1-800-626-2002 for GE factory parts
Replacement cooktop light bulbs
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
