If the stopwatch facility is a digital LCD display, then you probably have a watch with TWO batteries. One for the electronics and one for the analogue hands movement. The Electronics circuit board can be lifted out, revealing the smaller hands battery.
Hi John
this model does not have a tachymeter only day date function on sub dials. there is a similar model 10962j which uses the same case this has the tacho function.
Okay, so I'd the watch dial says automatic or manual wind you should be able to wind the watch to get it to start working. If the second hand is sweeping buy the minute and hour or just minute hand does not go around properly there are different issues. One. It could be the pinion that is loose, (major repair) two, the watch needs an overhaul meaning cleaned and re oiled(less likely). If only minute hand is giving trouble, its loose(the 2nd hand) or the pinion is loose.
You may have two batteries, there are watches with a lithium battery and a not so obvious silver oxide cell underneath. I don't know what watch you have so I cannot tell you for sure if this is the case
The problem is in chronograph module or related gear train. To find what exactly the problem is, special tools and equipment is needed as well as watchmakers knowledge and skill. There may be just an underpowered battery, but according to your explanation, I tend to think that the first causes mentioned by me are the right ones. Visit your nearest watch repair shop and ask to check your watch for any faults. Rate me, please.
Hello! Absolutely astonished by this "solution" from escapement. This watch is working perfectly - it is simply giving its "end of battery life warning".
