SOURCE: climate control eatc trouble code 12 and 49 any clues
you can take it to a dealer and have them run a diagnostic on it or simply ask them, you can also buy a tester at autozone that will tell you what is going on
Trouble Code: P0722
A/T Pulse Generator 'B' Sensor Circuit Malfunction
Possible Causes:
Pulse generator 'B' (+) or (-) circuit is open or shorted to ground .
Pulse generator 'B' is damaged or has failed.
TCM has failed .
TSB 01-40-006-1 (12/01) contains information about this code.
Trouble Code: P01529
Customer Snapshot Request Error
Possible Causes:
Transmission control module error.
Check for trouble codes in the transmission control module.
TSB 1-40-005 (3/01) contains information about this code. I have info. on these 2 codes,will search more for the others.
